ef-1
is the ef-1 ss valvetrain an retainers good and are they reliable on a DD. also can they work with other cams besides the ef-1 for ex. can they work well with ITR,Sk2,crower and such
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">is the ef-1 ss valvetrain an retainers good and are they reliable on a DD. also can they work with other cams besides the ef-1 for ex. can they work well with ITR,Sk2,crower and such</TD></TR></TABLE>
Yes, they are design to hand 10K+ rpms and not break.
Hey Rocket, got a question. Out of all your B-series VTEC cams, which ones actually make power to 10,000+ RPMs? It's nice having the valvetrain components to handle those revs, but do you sell a cam set that will actually ever see that high of a RPM?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">are ef-1 springs to stiff for the ITR cams?</TD></TR></TABLE>Good question.
Also, how much lift are they safe for?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a ferio »</TD></TR><TR><TD CLASS="quote">Hey Rocket, got a question. Out of all your B-series VTEC cams, which ones actually make power to 10,000+ RPMs? It's nice having the valvetrain components to handle those revs, but do you sell a cam set that will actually ever see that high of a RPM?</TD></TR></TABLE>
Have you seen the specs on his cams?
Rockets also working on some other badass stuff to add to his product line-up... browse the forums at http://www.ef-1.com
They will be overkill for the itr cams. If you only plan on using itr cams forever then run itr springs, if you are going to get bigger cams than itr, toda a's, skunk stage 1's, jun 2's, then get the ef1 valve springs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itec311 »</TD></TR><TR><TD CLASS="quote">They will be overkill for the itr cams. If you only plan on using itr cams forever then run itr springs, if you are going to get bigger cams than itr, toda a's, skunk stage 1's, jun 2's, then get the ef1 valve springs. </TD></TR></TABLE>
overkill in what terms?
imo the ef-1 valvetrain is at a great price..
and would be the most dependable.
would also give you the option of going with more aggressive cams later on down the line.
too stiff, I supose for ITR's, but I'd much rather have too stiff than too light. Its like a large throttle body. Better too big than too small. If the springs were too stiff how would it hurt the valvetrain in the short term?
-edit-
I supose it lock up that extra 1 1/2 horsepower....
-edit-
Stock ITR valvetrain floats badly if you have have lighten flywheel, Lower Final Drive, and compression break or downshift alot. The stock retainer is too heavy in my opinion for the stock ITR springs for performance use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket »</TD></TR><TR><TD CLASS="quote">
Stock ITR valvetrain floats badly if you have have lighten flywheel, Lower Final Drive, and compression break or downshift alot. The stock retainer is too heavy in my opinion for the stock ITR springs for performance use.</TD></TR></TABLE>
So they would be fine for itr cams in a gsr?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redGSRguy »</TD></TR><TR><TD CLASS="quote">
So they would be fine for itr cams in a gsr?</TD></TR></TABLE>
Nope.
Nope.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">For the springs/retainers, I have personally seen in a first gen B16A handle over 10,000 RPM's for a few minutes. Amazing IMO.
Ef-1 valve train is awesome
would you be talking about timmay?
</TD></TR></TABLE>would you be talking about timmay?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ninja_Jc7 »</TD></TR><TR><TD CLASS="quote">
would you be talking about timmay?</TD></TR></TABLE>
Yep.
Yep.
Yep.</TD></TR></TABLE>
who? J/K. yea i had my internally bone stock b16a with EF-1 springs/stock retainers to 10k a few times, didnt make power put didnt blow up or float!!!
in my book
in my book
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">
in my book</TD></TR></TABLE>
Boner, sorry about not callin you back. I`ll call j00 back tonight
that B16 ripped some people up. Won't name who though
in my book</TD></TR></TABLE>Boner, sorry about not callin you back. I`ll call j00 back tonight
JTurbo
Jul 10, 2004 12:54 PM
