Best D-series motor
Old Oct 16, 2003 | 10:55 AM
trigga's Avatar
Default Best D-series motor
what is the best d-serise motor, and what model and year can i find it in??
Old Oct 16, 2003 | 10:59 AM
-KangaRod-'s Avatar
Default Re: Best D-series motor (trigga)
D17a2
It was a SOHC vtec 1.7 litre found in 00+ Civic Ex's and 1.7 EL's
Its the biggest of the D-series, and bigger is better.
Old Oct 16, 2003 | 01:13 PM
b20_ed's Avatar
Default Re: Best D-series motor (-KangaRod-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -KangaRod- &raquo;</TD></TR><TR><TD CLASS="quote">D17a2
Its the biggest of the D-series, and bigger is better.</TD></TR></TABLE>
Yep! My friend's 01' EX hangs with the 99-00 SI's pretty damn well.
Old Oct 16, 2003 | 01:15 PM
ParrisEngineDynamics's Avatar
d16a6 head
Old Oct 18, 2003 | 12:20 PM
trigga's Avatar
are they ez to find? also how hard to swap in a 95 dx?
Old Oct 18, 2003 | 12:46 PM
DA6GSR's Avatar
good luck finding a new d17.
what are you gonna be doing with it? autox, drag, turbo, all motor or what? more details will be more helpful.
Old Oct 18, 2003 | 04:33 PM
trigga's Avatar
Default Re: (DA6GSR)
well i wanna stay all motor. im wanting to take most stangs and crap im not lookin for a vette eater(not happenin) yet i just want a fun & quick car and right now i got the 1.5 dx. light as hell(2442) with my dad(200) in the car.
Old Oct 18, 2003 | 11:46 PM
PHiZ's Avatar
Default Re: (trigga)
I've seen D17s. But they have returnless fuel systems, which causes a problem for some applications.
I don't know much more about them, they look like they have coil packs instead of plugs...
-PHiZ
Old Oct 19, 2003 | 09:43 AM
gear's Avatar
i beg to differ... D16y8 would be better, like the z6 but better intake manifold design... the a2 has a lame intake manifold *top intake style*...and the a2 does have ignition pack, no distributor.
i
Old Oct 19, 2003 | 07:34 PM
trigga's Avatar
Old Oct 19, 2003 | 08:15 PM
Default Re: (gear)
a d16y8 for all motor? Yes the y8 head does have smaller chambers and putting 88-89 integ pistons in the bottom end would increase the comp by a huge margin, but good luck trying to make that y8 head flow. Non-vtec is the way to go, less weight in the vavletrain, put in a big cam and you can also get those heads to flow pretty good. If you want vtec go with the z6 head and have the chambers welded. Just a few thoughts.
Old Oct 19, 2003 | 08:20 PM
DaNish's Avatar
Default Re: (ParrisEngDyn)
D15B
Old Oct 20, 2003 | 03:59 AM
trigga's Avatar
Default Re: (X DaNish X)
what is so good about the d15b?
Old Oct 20, 2003 | 08:02 AM
TrboInteg's Avatar
I'm going to have to say the D16a1/ZC is the best D series motor out of the bunch. It dosen't have vtec, but is does have dual cams which in my opinion makes it the best platform to build on.
Old Oct 20, 2003 | 11:09 AM
eg6ajk's Avatar
bottom end wise: d16a6
top (head) : d16z6
intake manifold : d16y8 (5spd)
exhaust manifold/header : 99-00 D16y8
flywheel: JDM 92-5 VXi D15b VTEC-E 15.8lbs flywheel
cam: JDM 92-5 D15B sohc vtec (for sohc vtec heads (ala d16z6/d16y8))
tranny wise: JDM S20 LSD equipped VTi tranny (due to LSD) - gearing wise same/simliar to 96-00 Y8 as well.
Old Oct 20, 2003 | 11:19 AM
senpai's Avatar
Default Re: Best D-series motor (eg6ajk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk &raquo;</TD></TR><TR><TD CLASS="quote">bottom end wise: d16a6
top (head) : d16z6
SoHc Ej1
Jan 18, 2008 09:03 PM
slammed94ferio
Nov 1, 2006 05:14 PM
Versatilx1
Jan 7, 2006 04:56 PM
tjc74
Apr 16, 2004 10:51 AM
Toxic H
Feb 5, 2004 08:25 PM
