Oil Light Goes Off and On ???
after my alternator took a **** on me.. left me stuck in pasedena for like 3 hours.. my gf's dad replaced the alternator.. now it holds a steady idle...before the alternaotr was replaced the idle was pretty funny, rpms would fluctuate from 1300 rpm to 500rpm... but now my oil light flickers on and offmostly when i gas it... i checked my oil and it was at a normal level.. any idea's? can it be a short?? any help will be appriciated thanks...
it could be a short, but i wouldn't risk it, i'd get your oil pressure checked out, if your oil pump takes a dump, you won't be able to drive a mile before something in your engine gives out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonGP4 »</TD></TR><TR><TD CLASS="quote">it could be a short, but i wouldn't risk it, i'd get your oil pressure checked out, if your oil pump takes a dump, you won't be able to drive a mile before something in your engine gives out.</TD></TR></TABLE>
damn it
damn it
u can get a high flow oilpump for like 150 http://www.importperformanceparts.net
but from what ive read on here befroe the flickering of the oil light was either a short or the oil pump goign out, like the other person mentioned get a oil pressure check done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane »</TD></TR><TR><TD CLASS="quote">how long did you drive you car with the oil light?</TD></TR></TABLE>
2 days
2 days
there could be a few reasons for the oil light flickering.
1. Loose or failed electrical connection
2. Low oil level
3. Damaged oil pan w/ damaged pick ups
4. Clogged oil screens or oil lines
5. Bad oil pump
Oil pump is pretty costly if you have it done by a shop probably between $300-$500
If you can do your own timing belt and water pump you could probably do your own oil pump.
hope this helps
Later
Matt
2. Low oil level
5. Bad oil pump
hope this helps
Later
Matt
... now the oil ligh stays on most of the time, and the oil level is fine...
thanks man... im gonna check my oil pressure first thing tommorow... aah ****.. stupid old motors,
I had the same prob. w/ my dohc zc. I was going to a friend's house, and my oil light started flickering. I pulled over and checked my oil. It was full. I got a bit worried, but still drove on it. I was already taking it to a shop to get work done, so I had them check it out. One of the mechanics just moved the wires around a bit, and the oil light went out. All it was is the wires had a short in it. Good luck with your problem, hopefully it will be the same solution as mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ef ***** »</TD></TR><TR><TD CLASS="quote">Did you ever bottom out and hit the oil pan? </TD></TR></TABLE>
heck yah i bottom it out all the time, looks like it gone thourhg hell and back
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by insomniac791 »</TD></TR><TR><TD CLASS="quote">yea I have heard of the oil filter giveing bad pressure. Maybe try an oil change. But I think that is too simple...but you never know
later
Matt</TD></TR></TABLE>
i think im gonna give that a try
later
****, it was the oil filter, my gf's dad repalced it because he said he dented the old one up when he was chaning the alternator... he put on some generic "dynomax" or something oil filter.. i changed my oil and put a fram filter on and the oil light disappeared....
