When i press Gad pedal down, rpm's drop, and almost stalls the car until i let go.
it does this while idl'ing, instead of revving, it drops, car has been sitting for 4 months, has low stale gas, old oil. Is it just in need of a tuneup? or is something else wrong?
is it throwing a code?.. 4 months isn't to bad, my HB ran with gas as old as over a year, it was pinging like hell but ran.. sounds like a bad TPS tho, but it would throw a code if it was bad.. just my 2 cents
Take her to the parkway n let her open up!!!
4 months is nothing prolly jus needs to be driven again
i have the same problem. But w/ me it only happens when the car is cold, Let it sit until its warmed up. then after rev it and see if it goes away. This is what i would do. And it started happening ever since it threw the TPS code. So change your TPS and it should go away hopefully.
89civichatchback
Aug 11, 2003 07:44 PM
