Will putting cheap coilovers at full height blow my shocks?
Old Oct 15, 2003 | 03:41 PM
Slow89HB's Avatar
Default Will putting cheap coilovers at full height blow my shocks?
I got some cheap coilovers and was wondering if I'll blow my shocks even if they are at full height...will they?
*lowering springs are on the car now..so i hope these are a lil softer*
Modified by Slow89HB at 1:29 AM 10/16/2003
Old Oct 15, 2003 | 03:44 PM
bryant's Avatar
Default Re: Will putting cheap coilovers at full height blow my shocks? (Slow89HB)
if they are close to stock ride hight they probley wont do anything but give a stiffer ride then stock. Its when ppl lower it and then ride on them for a long while that they blow them.
Old Oct 15, 2003 | 05:11 PM
carsaregood's Avatar
Default Re: Will putting cheap coilovers at full height blow my shocks? (Bryant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryant &raquo;</TD></TR><TR><TD CLASS="quote">if they are close to stock ride hight they probley wont do anything but give a stiffer ride then stock. Its when ppl lower it and then ride on them for a long while that they blow them.</TD></TR></TABLE>
i don't really understand this? how does the ride height effect shock life?
i was thinking that the height wouldn't matter, and that simply increasing the spring rate for a stock shock with stock damping rates would over work the shock, leading to increased wear rates... i'm just thinking aloud
edit: maybe the decreased shock travel has some effect i didn't think about?
Old Oct 15, 2003 | 09:10 PM
bryant's Avatar
Default Re: Will putting cheap coilovers at full height blow my shocks? (carsaregood)
Your edit is right. The decreses shock travel and most slam there car, so the shock usually ends up bottoming out. Also since its lowered it would ride much stiffer with the higher spring rates and the no shock travel. Blowing shocks doesnt usaully happen right after someone would lower there car on stock springs. I know some that have gone a couple years and there shocks still work fine. (for now )
If left at, or close, stock ride hieght the shock will not be compressed and or bottom out. The stiffer springs rates wont do much but give the car a stiffer ride.
Old Oct 15, 2003 | 09:44 PM
FR-MOB: ThE bEe GuY's Avatar
If you wanna have a longer shock life with a lowered car, you'll have to spend a little more money, but it can be done. But back to the subject, it most likely wont blow your shocks if you're close to stock height.
Old Oct 15, 2003 | 09:48 PM
CleenSi
Guest
Posts: n/a
Default Re: Will putting cheap coilovers at full height blow my shocks? (ThE bEe GuY)
more pressure set on the shock.
type-ONE
Suspension & Brakes
31
Aug 28, 2009 11:01 AM
kpjo4
Aug 7, 2008 04:30 AM
Shingo
Suspension & Brakes
Aug 25, 2005 02:08 AM
EKB18BPR3
11
Aug 18, 2002 05:05 PM
Duck Sauce
Dec 21, 2001 07:58 AM
