break pad noise
Old Oct 15, 2003 | 01:42 PM
All-Star's Avatar
Default break pad noise
I just put Hawk HP plus pads on my car and they are beyond just a small squeak its more like a grit your teeth, close your ears, and pretend its not you because everybody is staring kinda of noise that is coming from them. Any help would be great.
D
Old Oct 15, 2003 | 01:44 PM
spaceman's Avatar
Default Re: break pad noise (All-Star)
did you grease up the backside of the pads?..you gotta do that,also make sure they are installed correctly
Old Oct 15, 2003 | 01:50 PM
All-Star's Avatar
Default Re: break pad noise (spaceman)
They are installed correctly. What do you mean by grease up the backside of the pad?
Old Oct 15, 2003 | 02:15 PM
RHD_BB4T's Avatar
Synthetic grease or "anti-squeal" compound should be used when installing new (stock) brake pads to keep them from squealing...I'm not sure about performance/aftermarket pads though. You'll want to grease the mounting clips, the back side of the pads and/or the shim that goes between the caliper and pad... HTH
Dan P.
Old Oct 15, 2003 | 05:14 PM
All-Star's Avatar
Default Re: break pad noise (Dan_P)
I'm going to try that tomorrow as well as getting the rotors resurfaced I think that might also be part of the problem. Its definately coming from the rotor on the right side and it only happens when I press the break softly. Under hard breaking its fine.
D
DaveSi677
Honda Civic (2006 - 2015)
Nov 12, 2011 04:44 PM
dlprince
Suspension & Brakes
Nov 11, 2008 04:11 PM
icebluecivic21
Apr 29, 2008 10:56 PM
Floyd
Sep 18, 2001 07:29 PM
