Suspension Problem??
When i go over a bumb i hear a small bump from something in my front passenger side area
i think it happens on turns sometimes to . also my wheel clicks when i turn it past 1/4 of the way. but the click sounds like its inside the cabin as opposed to under the hood?
91 CRX Si
i think it happens on turns sometimes to . also my wheel clicks when i turn it past 1/4 of the way. but the click sounds like its inside the cabin as opposed to under the hood? 91 CRX Si
Could be a bad axle for the clicking. As for the bumping noise could be your front bushings, could be a tie rod end, could be a ball joint. Quite a few things up front can make noises when going bad. I would say jack up your car and grap onto your wheel and see if there is any up and down play or side to side play (not from the steering) and then go from there. Also while you have it jacked up check out your axles and see if you have a torn boot or grease splattered everywhere for that matter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vinceg99 »</TD></TR><TR><TD CLASS="quote">Could be a bad axle for the clicking. As for the bumping noise could be your front bushings, could be a tie rod end, could be a ball joint. Quite a few things up front can make noises when going bad. I would say jack up your car and grap onto your wheel and see if there is any up and down play or side to side play (not from the steering) and then go from there. Also while you have it jacked up check out your axles and see if you have a torn boot or grease splattered everywhere for that matter.</TD></TR></TABLE>
What he said..... oh y tu eres un cabron no yo.... P
Ok i've been checking this out
i jacked the car... changed the rotors looked all around..
all boots/seals look good
no play at all
WTF..... i'm startin to think that it could be my cold air intake floppin around..
gonna go check that out right now.
Modified by Eresuncabron at 10:47 AM 10/24/2003
no play at all
rice_classic
Dec 11, 2004 05:15 AM
