JRSC & Fuel rail
Old Oct 15, 2003 | 11:21 AM
preludesh012001's Avatar
Default JRSC & Fuel rail
I have a set of brand new 370cc r/c injectors and a aem fuel rail and fpr and a b&m fuel gauge mounted on the rail. I was wondering if this will all fit with the blower or will i have to modify something? Also Will i need a new fmu? I know shark can help me
Old Oct 15, 2003 | 12:25 PM
sharkcohen's Avatar
Default Re: JRSC & Fuel rail (preludesh012001)
I don't know for sure about the fuel gauge, but the other components will fit fine.
Old Oct 15, 2003 | 02:29 PM
So theres no need to modify anything? Also how hard is removing the blower? Will i need a different FMU?
Old Oct 15, 2003 | 04:46 PM
Due to the 370CC R/C injectors?
Old Oct 15, 2003 | 04:52 PM
sharkcohen's Avatar
Default Re: (preludesh012001)
You could get off with using the JR FMU, as you should be able to pull enough fuel out with the vafc. However, getting yourself an FMU with an adjustable rise rate, such as a Car Tech, would allow you to get your peak pressure down. I've never been comfortable with the idea of running fuel pressures higher than 100 psi, although many claim it's not a problem.
Are your 370s saturated or peak/hold?
sharkcohen's Avatar
Default Re: (sharkcohen)
Oh, although I haven't removed it myself yet, having installed the blower I'm sure removing it is as much a bitch.
Modified by sharkcohen at 2:07 AM 10/16/2003
Old Oct 15, 2003 | 04:59 PM
thats not good to hear. There R/C 370cc injectors saturated. How hard will this be to install? The IAC and nothing should get in the way?
Old Oct 15, 2003 | 05:06 PM
sharkcohen's Avatar
The injectors will fit fine, you don't need to worry about that.
Old Oct 16, 2003 | 03:03 PM
I also got a pair of clips, i have to cut the stock injecor clips to install these? I cant use the stock clips?
Old Oct 16, 2003 | 05:40 PM
sharkcohen's Avatar
Dude, your injectors are saturated, you don't need new clips.
JDC2TypeR
Aug 25, 2007 11:32 AM
I8ayellowcrayon
Aug 9, 2005 09:39 PM
redsled00
Jun 23, 2005 06:38 AM
nigel
Jul 11, 2003 08:57 PM
