Questions on b16a swap i couldnt find with the search feature
Old Oct 15, 2003 | 10:26 AM
p3s7's Avatar
Default Questions on b16a swap i couldnt find with the search feature
Alright so I have an 88 CRX Si, and can't figure out everything I'll need. These are the things I know i'll need:
Complete b16a swap (incl ecu, harness, and all that)
mounts
modified shift linkage
hasport harness
This is where I get confused. Will i be able to use the axles that come with the swap in my car? If not, is there any point in ordering the "complete swap" and instead just getting the motor, tranny, ecu? And if those axles do not work I'm supposed to use DA axles correct, will that work with my Si hubs? or will I need DA hubs as well? I've also heard things about needing DA steering knuckles as well? Can someone clear this up for me on exactly what I would need to get the swap up and running not considering maintenance things such as distributor, alternator, timing belt, clutch and all that. I'm only asking for the things I would need if all of that came in good running condition. Thanks
Old Oct 15, 2003 | 10:40 AM
Redline130's Avatar
Default Re: Questions on b16a swap i couldnt find with the search feature (p3s7)
Unless the swap comes with a Y1 tranny and intermediate shaft, you can use 90-93 Integra axles no problem. You will not have to change your hubs or knuckles.
Old Oct 15, 2003 | 10:45 AM
roadawg's Avatar
Here you go
https://honda-tech.com/zerosearch
aero162
Aug 29, 2006 08:08 PM
CRX-SIR
11
Jan 23, 2005 12:47 AM
Dainbramage
Apr 25, 2004 08:06 AM
94civic_EX
Jun 25, 2003 06:27 AM
Sirex
Dec 28, 2002 05:53 AM
