HELP! DPFI to MPFI PROBLEM!
Old Oct 15, 2003 | 08:36 AM
RotiEatter's Avatar
Ditto
Default HELP! DPFI to MPFI PROBLEM!
I just did a DPFI to MPFI swap on my B18A in my 1990 CRX DX. It isn't throwing any codes but it sputters at like 20% throttle and almost dies when i push in the clutch b/c the revs drop to like 400 rpm's then go back up to 600ish. I have gone over the wiring a couple times and I have gotten others to look over it as well, and it seems fine. Another thing is that I can smell exhaust fumes a lot more than I could before. Thanks for any help you guys can give me.
Old Oct 15, 2003 | 10:08 AM
Targa250R's Avatar
be professional
Default Re: HELP! DPFI to MPFI PROBLEM! (RotiEatter)
Sounds like it is running very rich for some reason, could be a few problems including IACV, O2 sensor, and/or vacuum leaks.
Old Oct 15, 2003 | 11:25 AM
FourthGenHatch's Avatar
Unstable idle sounds like an EACV/IACV (same thing) problem. Is that all the time? Or just before the engine is warmed up.
Old Oct 15, 2003 | 03:31 PM
RotiEatter's Avatar
Ditto
Default Re: HELP! DPFI to MPFI PROBLEM! (FourthGenHatch)
Mainly just before the engine is warmed up. I found out my #1 injector is leaking today sice there was some brownish stuff on the manifold right under the injector and i could smell fuel, so I am going to fix that. You think that could be my problem?
Old Oct 15, 2003 | 03:37 PM
EG8R's Avatar
This sounds a little familiar to me. After my MPFI swap I noticed that the exhaust smell was alot stronger.... Going by what you guys have said, its running rich. And probably the reason why the back of my car is covered in black.... Hmmz....
Any idea what I can do to lean it out a bit?
Old Oct 15, 2003 | 03:39 PM
HONDABOND's Avatar
sounds like that injector was dumping fuel. Also, check your vacume lines... I have been working on mine and I know something is ******* sit up.
Old Oct 15, 2003 | 04:47 PM
JDMHatch101's Avatar
Default Re: HELP! DPFI to MPFI PROBLEM! (HONDABOND)
how many o2 sensors do you have? i had the same problem with mine, found out it was my o2s. to lean the car out get a fuel pressure regulater. 36-40 psi. good luck
Old Oct 15, 2003 | 05:33 PM
RotiEatter's Avatar
Ditto
Default Re: HELP! DPFI to MPFI PROBLEM! (JDMHatch101)
I have a fuel pressure gauge and it is reading around 40 PSI at idle. I have 1 o2 sensor.
Old Oct 15, 2003 | 07:12 PM
Grease Monkey's Avatar
did you have to mess with the tps?
Old Oct 16, 2003 | 05:05 AM
RotiEatter's Avatar
Ditto
Default Re: HELP! DPFI to MPFI PROBLEM! (Grease Monkey)
I didn't mess with the TPS at all besides extending the wires. The car actually shut off on me twice today at idle. it also back-fired, should I just get a FPR and turn it down? TIA
Old Oct 16, 2003 | 04:46 PM
RotiEatter's Avatar
Ditto
Ok, I re-did the vacuum lines and now it no longer stutters or almost dies, but it won't idle properly at all. It's at 1700 then it will drop to 1000 then back up to 1700. Do I need to buy a new EACV? Will one off a B18B work or just one off a B18A? TIA.
Old Oct 16, 2003 | 07:37 PM
you still have a vaccum leak....
josh807
Feb 13, 2007 05:58 PM
vwhonda2gether
12
Sep 18, 2006 06:01 PM
janz3n
Apr 11, 2006 08:06 AM
pokemon
Jun 27, 2003 11:36 AM
RotiEatter
Jun 22, 2003 08:35 PM
