Question about AEM fuel rail
Old Oct 15, 2003 | 06:41 AM
tgreaves's Avatar
Default Question about AEM fuel rail
The aem website says that the fuel rail will accept either an6 or an8 fittings.. Which is it.. I dont think that both an6 and an8 fittings will go into the fuel rail..
Also I see aeroquip sells fitting for teflon steel braided hose.. Will these same fitting go on to a teflon hose that isnt steel braided.. Im trying to hook up my fuel pressure regulator to the return line and the return line isnt steel braided.. Thanks
Old Oct 15, 2003 | 07:33 AM
IN VTEC's Avatar
Default Re: Question about AEM fuel rail (tgreaves)
It's 9/16" x 18 threads/inch on the AEM fuel rail. That makes it -6AN threads. But....you can't use a -6AN flare directly on the end of it b/c there's no compression seat for the AN flare fitting. You have to use an AN 9/16" x 18 to -6AN flare port adapter.
Earl's part number: 985006
-this is an example of the part you need. I'm sure Goodridge and Aeroquip will have one too.
Old Oct 15, 2003 | 07:40 AM
tgreaves's Avatar
Default Re: Question about AEM fuel rail (IN VTEC)
Great.. I found the part on anplumbing.com.. What is the banjo bolt that fits the honda oem fuel filter on one end and has a an6 fitting on the other.. I saw a picture of it in another thread but cant find it anywhere else.. Thanks
Old Oct 15, 2003 | 08:05 AM
IN VTEC's Avatar
I don't know what the part numbers are for anything but the Goodridge banjos b/c they're the only ones that I've seen make them public knowledge. The other companies, like XRP, Russell, Earl's, and Aeroquip should have their own versions as well.
Goodridge 776-06-M12....decodes to: fitting type-AN size-banjo ID
The anodized aluminum banjos are really expensive, but that's all they offer that piece in. A simlar 776-04-M14 I bought once cost ~$38.
Old Oct 15, 2003 | 10:16 AM
tgreaves's Avatar
Wow.. Is there a cheaper way like threading an adapter into the hole for the factory fuel filter instead of using a banjo fitting then..
Old Oct 15, 2003 | 10:25 AM
IN VTEC's Avatar
Yes. You'll need to find the right combination of fittings to convert the M12x1.00 (F) fitting to a -6AN fitting....whether it be by converting over to a pipe fitting then to -6AN, or directly to -6AN.
Then use the same -6AN port adapter I listed above on the feed end of the fuel rail. You'll lose the pulsation dampener, but the larger ID bore of the fuel rail should help with that.
Old Oct 15, 2003 | 10:41 AM
tgreaves's Avatar
Ahh... M12x1.00 is what I didnt know.. Where are you getting the factory sizes from or do you just know them.. Also where is the best place to get the fittings.. Im looking on anplumbing.com but there website has incomplete information..
Old Oct 15, 2003 | 10:59 AM
tgreaves's Avatar
What about fitting 840106.. Is has a male 9/16 x 18 to an an6 hose.. This would be for the fuel rail and it says that its an o ring fitting..
Old Oct 15, 2003 | 11:37 AM
IN VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">What about fitting 840106.. Is has a male 9/16 x 18 to an an6 hose.. This would be for the fuel rail and it says that its an o ring fitting..</TD></TR></TABLE>
Sounds like it'll fit, but the one I listed is cheaper by like $4. Maybe the one you listed already has the hose-end already integrated.
About the thread sizes and pitches...I just get used to knowing them from working with certain apps so often. If I'm unsure, I use a pitch gauge to help me figure it out.
Old Oct 15, 2003 | 11:47 AM
tgreaves's Avatar
It does already have the hose end on it.. Do you sell the fittings or just work with then alot..
Old Oct 15, 2003 | 12:04 PM
IN VTEC's Avatar
I get most of my fittings from our local domestic shop (Extreme Performance), the Goodridge branch in Indy (specialty items), Racer Parts Wholesale (Aeroquip firesleeve and pipe-to-AN adapters), and Summit Racing (hose-ends and everything else).
If you want pricing, talk to Flamenco-t (Stan). He sells mostly Goodridge pieces. He can probably get or find what you need. He should have catalogs on hand.
Old Oct 15, 2003 | 01:39 PM
tgreaves's Avatar
Are you sure its M12x1.00.. All I can find anywhere is M10x1.00 or M12x1.5.. Just wanted to make sure before I keeping looking around..
grkblood13
Mar 30, 2009 02:42 PM
TylerC161
Sep 23, 2006 02:53 PM
Mr. Anderson
Feb 21, 2005 08:01 AM
oldbeefcake
10
Jan 13, 2004 10:04 PM
Que_Lude
Feb 2, 2003 10:07 PM
