Duty Cycle
Old Oct 15, 2003 | 06:11 AM
Littleton's Avatar
Default Duty Cycle
While conducting a private track day I noticed that my data was posting duty cycle above 80% from time to time with the max being at 100% for a half a second at one point. At what point should one move up in the injector size? I heard the rule that 80% is the threshold but I wanted to hear from some experts on this on.
Old Oct 16, 2003 | 11:53 AM
Littleton's Avatar
Default Re: Duty Cycle (Littleton)
Anyone?
Old Oct 16, 2003 | 12:43 PM
Benny Hinn's Avatar
Upgrade to larger injectors.
It would be horrible for you to lose an engine to an injector failure.
I would run a larger injector with less fuel pressure so that if I ever needed more fuel, I could just increase the pressure a bit.
Old Oct 16, 2003 | 01:01 PM
b18bturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Littleton &raquo;</TD></TR><TR><TD CLASS="quote">While conducting a private track day I noticed that my data was posting duty cycle above 80% from time to time with the max being at 100% for a half a second at one point. At what point should one move up in the injector size? I heard the rule that 80% is the threshold but I wanted to hear from some experts on this on.</TD></TR></TABLE>
you want to keep your duty cylce around 80-90% its not bad thing you hit 100% but your injector is completly open. If it faiels and cant provide enough fuel then kaboom everything goes. so i would listen to the above post and get larger injectors. if you need some contact me.
Old Oct 16, 2003 | 02:16 PM
Benny Hinn's Avatar
Default Re: Duty Cycle (b18bturbo)
An upgraded injector is far cheaper than a blown engine.
PirateMcFred
Apr 9, 2010 10:58 PM
EKhothatch
May 4, 2006 05:30 AM
Excelerate
Jul 7, 2005 12:15 PM
ceLtic
May 10, 2004 05:06 PM
KamikazeSol
Nov 7, 2003 07:12 PM
