is there a such thing as safe boost
Old Oct 15, 2003 | 05:56 AM
tencan's Avatar
Default is there a such thing as safe boost
i want to know is there a safe amount of psi i can run thru a (sohc) zc ? safe before i have to change internals. would it be a complete waste of time ... ofcourse fuel managment is a definite, timing etc. but as far as the strenth of the block is it safe to run 4 - 6 psi via a t3
Old Oct 15, 2003 | 06:43 AM
nevin's Avatar
no.
Old Oct 15, 2003 | 06:51 AM
phan's Avatar
Default Re: is there a such thing as safe boost (sodacan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sodacan &raquo;</TD></TR><TR><TD CLASS="quote">i want to know is there a safe amount of psi i can run thru a (sohc) zc ? safe before i have to change internals. would it be a complete waste of time ... ofcourse fuel managment is a definite, timing etc. but as far as the strenth of the block is it safe to run 4 - 6 psi via a t3</TD></TR></TABLE>
tuned right, i've seen stock blocks handle high psi numbers...but a safe amount of boost on your zc would be about 6psi if everything else is done right...
Old Oct 15, 2003 | 06:58 AM
virginia_dude's Avatar
I'm no autority but if you plan to run 6psi WHY go with a T-3 get a T-25 of other small one, the handle that easy and spool up much faster.
Old Oct 15, 2003 | 07:15 AM
tencan's Avatar
Default Re: is there a such thing as safe boost (virginia_dude)
only thinking about a t3 because i have a brand new one ,that ive had from bfore i got my crx
thats all..hjope to use it on a b series.just testing the waters if you kno what i mean(as far as hondas).. i used to have a 2.0 gti and the t3 was perfect but then again 1.6 and 2.0 is a big differnce..but thats my reasoning...
thanks for the input.
Old Oct 15, 2003 | 07:23 AM
Well using what you have already makes sense to me. Just be carefull and make sure to do the appropriate fuel management things, hate to see you smoke a perfectly good motor for being lazy. You could run more than 6 with proper tuning. But the Proper tuning is the key to everything.
dipsetking
Jun 26, 2007 01:37 PM
h22_crx
Oct 24, 2005 07:19 PM
EARLdaSQUIRREL
Oct 21, 2003 09:29 PM
VTgringo
May 27, 2003 03:02 PM
1990hondaHF
Oct 22, 2002 08:18 AM
