srs light still not off....
Old Oct 15, 2003 | 12:37 AM
racerboyb18c1's Avatar
Default srs light still not off....
i did the reset prosedure and the light went off for like 6 seconds and then came back on i know i did this right cus i had a friend thats done it do it and i read on it and did it like 10 times stock steering wheel and what not never been hit whats the deal ? ne one ? by the way 96 ek with lsvtec if u need to know...
Old Oct 15, 2003 | 04:10 AM
sackdz's Avatar
Default Re: srs light still not off.... (racerboyb18c1)
There is somthing wrong with the system. Pull the SRS code.
Old Oct 23, 2003 | 09:43 PM
cxSHOE's Avatar
Default Re: srs light still not off.... (sackdz)
do it again, get the manual in my sig.
Old Oct 26, 2003 | 10:40 AM
sackdz's Avatar
Here is the procedure you should be using:
The entire process is outlined in section 23 of the helms manual. To do this you need to short the MES connector, which is the yellow connector that clips to the front of the interior fuseblock. Pull it out and short it with a service connector/paperclip and then it goes something like this...
-Ignition off: Short MES connector
-Ignition on: SRS comes on and then goes out. within 4 seconds open connector (remove short)
-SRS light comes on. Within 4 seconds short connector.
-SRS light goes out. Within 4 seconds open connector (remove short).
-SRS light blinks twice and goes off indication sysytem has been reset.
jjs316
Jul 21, 2006 02:18 PM
aznrexboi00
Jan 30, 2004 09:00 AM
Snail EK
Nov 12, 2003 09:51 AM
2qwik2nv
Oct 24, 2002 08:10 PM
mrlegoman
Oct 25, 2001 05:20 AM
