d-4 tranny light?
I was wondering what it means when this light flashes and the car does not want to start.My 93 Accord 10th anniversary has done this once and I am just wondering what it means.Someone....anyone please help.
how many blinks? probably an indication of a bad switch or solenoid -- the TCU
is probably malfunctioning ... could be just a simple short
the wire harness in the TCU could have tapped one of the main relay to the ignitor (explains why you can't start the car) since they do share the same bundle.
stays on steady.also i forgot to mention when it did start the gear that it was in that light came on as normal but the d4 stayed lit up and the car would not go past 2grand even to the floor unless it was in gear 1 or 2.
it's late -- no replies so i'm going to bed
try to get the ecu code by short'ng the blue two pronged service
check connector that hangs beneath the passenger kick panel
the CEL will flash a series of long/short flash that will ya the code
go here to decipher
http://tech.hybridgarage.com/tech/codes.html
http://hybrid2.honda-perf.org/tech/codes.html
go here to decipher
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93AccordGirl »</TD></TR><TR><TD CLASS="quote">yes it was flshing on the dash.it is wierd no cel and it has only done it that one time.</TD></TR></TABLE>The D4 lamp is what the transmission controller uses for it's errors. The check-engine light is for the engine...
primemal
Aug 7, 2006 09:09 AM
