lights are flickering what do i do
Old Oct 14, 2003 | 07:57 PM
dirty_d_cx's Avatar
Default lights are flickering what do i do
i have a very annoying problem and i cant figure out what it is
when my car is running i will get a slight dim that is repettitive
the inerior lights headlights fuel pump and everything that is electrical
pulses. i know my fuel pump is doing it because my fp guage drops about two psi an rises again. it is now getting so bad that it is causing my idle to drop
about 100 rpm. also my air/fuel ratio guage blanks out every once and a while
it will go from a stoich reading and suddenly shift all the way to the extreme of the rich side and their is no strobing effect like there was when i first put it in
i appreciate any help you guys can give because it is driving me insane
also i have had my alternator tested and it is fine
Old Oct 15, 2003 | 08:03 PM
dirty_d_cx's Avatar
Default Re: lights are flickering what do i do (dirty_d_cx)
does anybody have any help for me
Old Oct 15, 2003 | 08:06 PM
Lord Helmet's Avatar
sounds like you either got a loose ground wire somewhere or a short in the wiring harness. check ALL connectings.
Old Oct 15, 2003 | 08:29 PM
dirty_d_cx's Avatar
Default Re: lights are flickering what do i do (sleeperciv)
i have checked all of my grounds but i havn't checked my wiring harness
do you think i would need to check my underdash harness also
STATek9
16
Aug 2, 2009 12:44 PM
PonoED
11
Aug 30, 2008 04:30 PM
Yellowone
12
Apr 25, 2008 12:51 PM
civic efb16
Aug 6, 2005 03:02 AM
madman13lm
May 13, 2003 05:53 AM
