LS/GSR VTEC vs GSR???
Old Oct 14, 2003 | 07:38 PM
youngwon22's Avatar
Default LS/GSR VTEC vs GSR???
do you think ls with gsr head would be any better than a stock gsr? thanks for any replies
Old Oct 14, 2003 | 07:39 PM
LSTEG96's Avatar
Default Re: LS/GSR VTEC vs GSR??? (youngwon22)
http://www.importreview.com has some dyno sheets that might help u out...
Old Oct 14, 2003 | 07:43 PM
VTECorona's Avatar
Default Re: LS/GSR VTEC vs GSR??? (LSTEG96)
My friends LS\VTEC dyno'd at 166 with bolt-ons, vafc, and tuning.
Old Oct 14, 2003 | 07:44 PM
ggangtong81's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngwon22 &raquo;</TD></TR><TR><TD CLASS="quote">do you think ls with gsr head would be any better than a stock gsr? thanks for any replies</TD></TR></TABLE>
oh yeah no doubt about it. ls/vtec will put some good numbers. however, u need to build it right, otherwise, you'll be in a deep trouble. search a whole lot before you even think about putting ls/vtec.
P1mpSlap's Avatar
what about RSVTEC? anyone rockin that?
Old Oct 14, 2003 | 09:23 PM
Shadow Racer's Avatar
Default Re: LS/GSR VTEC vs GSR??? (ggangtong81)
whats the difference between ls motor and the gsr besides v-tec and heads, what makes ls supposedly so much better. might be a dumb question to some but i know nothing.
Old Oct 14, 2003 | 10:48 PM
Street_Kings's Avatar
The B18b Block is very torquey. High Torque + High HP = Faster
Old Oct 15, 2003 | 04:14 AM
Doc_Honda's Avatar
Default Re: LS/GSR VTEC vs GSR??? (Shadow Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shadow Racer &raquo;</TD></TR><TR><TD CLASS="quote">whats the difference between ls motor and the gsr besides v-tec and heads, what makes ls supposedly so much better. might be a dumb question to some but i know nothing.</TD></TR></TABLE>
There is a very good article about this on http://www.team-integra.net
Old Oct 15, 2003 | 09:47 AM
Spoonin's Avatar
Default Re: LS/GSR VTEC vs GSR??? (Doc_Honda)
I had an idea about putting the 1st gen B16 in my car since it is the easiest and cheapest one for my car. When I want more displacement I will just put in a B18C1 block with ITR pistons and call it a day.
Old Oct 15, 2003 | 10:05 AM
Quiks66's Avatar
Default Re: (P1mpSlap)
I'm 'rocking the RSVTEC' as you put it. Just the same as Ls/Vtec but I think my RS has less sound-deadening material like the Type R does. I also don't have Cruise Control or a moonroof, which equals less weight.
Old Oct 15, 2003 | 05:31 PM
Default Re: (Street_Kings)
i knew that. my question was why its torquey.
Old Oct 15, 2003 | 05:39 PM
2muchGT's Avatar
Default Re: (Shadow Racer)
gsr has higher compresion than ls. ls/vtech with otherwise stock internals is gonna be worse off than stock gsr
Old Oct 15, 2003 | 05:41 PM
P1mpSlap's Avatar
no
Not if you still run the same compression as the LS. I raced some guy w/ LSVTEC way before I put in my CTR pistons and walked the dog on his ***.
Unless you bump up the compression you aren't using VTEC for what it was meant to do.
Old Oct 15, 2003 | 05:42 PM
P1mpSlap's Avatar
Default Re: (2muchGT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2muchGT &raquo;</TD></TR><TR><TD CLASS="quote">gsr has higher compresion than ls. ls/vtech with otherwise stock internals is gonna be worse off than stock gsr</TD></TR></TABLE>
ding ding ding ding we have a winner
Old Oct 15, 2003 | 05:55 PM
91tegrals's Avatar
nice reply..
Old Oct 15, 2003 | 06:01 PM
fuck honda-tech's Avatar
Default Re: (91tegrals)
i ran a ls/ vtec integra ... he had intake, ehaust, header, act clutch , flywheel .. i have a 99 gsr with intake exhaust and i walked my like a yo yo majority of the time
Old Oct 15, 2003 | 06:05 PM
P1mpSlap's Avatar
Default Re: (epsom salt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by epsom salt &raquo;</TD></TR><TR><TD CLASS="quote">i ran a ls/ vtec integra ... he had intake, ehaust, header, act clutch , flywheel .. i have a 99 gsr with intake exhaust and i walked my like a yo yo majority of the time </TD></TR></TABLE>
hell yeah. That **** is overated.
Old Oct 15, 2003 | 06:22 PM
^ lol sorry but u get the idea .. its like a rotory engine it may run strong for a while but one day ur gonna start it and the engine is gonna be toast !
Old Oct 15, 2003 | 06:29 PM
P1mpSlap's Avatar
mmmmmm Rotary...........
Old Oct 15, 2003 | 06:43 PM
lshybrid195's Avatar
if u build the lsvtec right from start it will not give u any problem but if u do it half *** u are jus askin for trouble
i myself have lsvtec and it a strong motor
Old Oct 15, 2003 | 07:35 PM
StyleTEG's Avatar
ugh.. no.
Compression is not the only factor in how an engine performs. Yes the higher compression is better suited for the more aggressive vtec cam profile, but to assume that with out it a ls/vtec (not vtech ) is going to be worse is just goofy.
The B18B has more torque because of its rod stroke ratio. By having a shorter stroke, it has more displacement. The result is more low/mid range torque at the sacrifice of revability. The higher you rev with a shorter stroke the more sideloading you get.
Which is why it is very important to build a LS/Vtec properly if you plan to rev higher than the stock LS redline.
so much misinformation
Old Oct 15, 2003 | 07:53 PM
VTECorona's Avatar
Default Re: (StyleTEG)
Like I said above, my friends put down 166 with just i\h\e vafc and dyno tuning. He has stock internals which means lower compression than a stock gsr. Does he have a freak motor or what.
We compression tested it and it was 240-255 across
Old Oct 15, 2003 | 08:02 PM
BolivianDc2's Avatar
Default Re: (VTECorona)
Along with LS/VTEC you also have to look at the transmission. A GSR tranny is closer geared than a LS tranny, so what will give the GSR the advantage in that realm.
Old Oct 15, 2003 | 09:00 PM
VTi NA's Avatar
If you're even going to bother with NA LSVTEC just go NA B20. You'll feel a lot more torque as the difference in displacement btwn a B20 vs B18C is obviously a lot larger than a 18B vs 18C.
Of course, you could always bore out the LS
Old Oct 16, 2003 | 04:32 PM
Spoonin's Avatar
Default Re: LS/GSR VTEC vs GSR??? (STi -RA)
I might go with a B20 and a B16a cable tranny with the LSD in my DA. I think my topspeed will be like 120-125 but, I don't need to go past that in a 1/4 anyway and it will get there pretty damn fast! Not to mention all that torque with those short gears and a LSD will haul *** off the line. No more waiting to get into your power curve.
