will this work with ITR swaybar?? (pics)
im about to install my ITR 22mm sway bar. i was at auto zone and i noticed they carry energy suspension stuff.
i bought these they said they will fit the 22mm sway bar
with all this stuff work or should i take it back?
They're around $15-$18 for the pair, and you can see they have zerks grease fittings so if they ever get noisy you just stick the grease gun on there and lube 'em up.
They only carry universal bushings for the most part, like the swaybar bushings (pretty standard stuff on all cars).
well i tryed to install with these bushings, the brackets are way to big and could not be used, and the endlink bushings dont fit ither, im just gona take them back in a few
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n0 iNTegRiTY »</TD></TR><TR><TD CLASS="quote">Did you see any shifter bushings when you were there?
I'm about to go check it out tomorrow at my Autozone
I picked up ES shifter bushings from PEPBoys this past weekend...10 bux.
</TD></TR></TABLE>I picked up ES shifter bushings from PEPBoys this past weekend...10 bux.
those endlink bushings weren't intended to work with our kind of endlinks. but i have those same sway bar bracket bushings with the nipples on them and they're great. you just have to keep them greased up or they'll squeak like a *****.
ya i used bsq kit, but the brackets on the ES bushings where way to big, it woulda crushed my abs thing. i just used the ITR ones and took the ES back to the store
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekone GBPDC2 »</TD></TR><TR><TD CLASS="quote">ya i used bsq kit, but the brackets on the ES bushings where way to big, it woulda crushed my abs thing. i just used the ITR ones and took the ES back to the store</TD></TR></TABLE>
Yea, i don't think those bushings work with any of the mounting kits. My swaybar was installed by reversing the GSR mounts so the stress isnt on the sheetmetal as much, I know they work if you install them like that.
boxedfox
Suspension & Brakes
Apr 22, 2018 10:35 AM
