Newer B18A into older hatch = smog legal right?
Guest
Posts: n/a
I am sure this has been covered before but for some reason I can’t find it. Anyhow my question is what would I need to do in order to make my car smog legal if I was to put a newer B18A into it? Please reply if you have any advice.
Thanks
w-a-o
Thanks
w-a-o
Once you're done w/ your swap, get an appointment with the State Referee for inspection. They will check your car and do a smog test too. If you pass, they will affix a BAR sticker on your engine bay or door jam that certifies the legal swap. Your motor should be the same year or newer than your car plus...hmmm. (just run a search on the other things)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">you will need the BAR sticker</TD></TR></TABLE>
i'm surprised the resident smog advisor-ness didn't come out temp...tell him what he needs!
in short, you'll need ALL smog equipment that came off the da integ/b18a motor...
