QUESTIONS on LS/VTEC
Old Oct 14, 2003 | 05:30 PM
gogou99's Avatar
Default QUESTIONS on LS/VTEC
after installing a ls/vtec in a 90crx(obd0) stock cams, timing, (everything stock)without chipping the ecu, should it run smooth, or like ****?
Old Oct 14, 2003 | 07:14 PM
TECH43 RACING INC.'s Avatar
Default Re: QUESTIONS on LS/VTEC (gogou99)
it should run like stock. smooth.
Old Oct 14, 2003 | 08:22 PM
gogou99's Avatar
Default Re: QUESTIONS on LS/VTEC (TECH43 RACING INC.)
can the knock sensor or o2 sensor make it studer and feel very slugish and weak (im just breaking in the motor)?
Old Oct 14, 2003 | 11:16 PM
99blackcivicSi's Avatar
What ECU are you running? Do you have an FPR? or Fuel pressure guage if so what is the fuel pressure at?
Old Oct 15, 2003 | 05:00 AM
gogou99's Avatar
Default Re: QUESTIONS on LS/VTEC (99blackcivicSi)
im running a pr3 obd0, i have a b&m fpr- 54psi, i cant controll it, i think i got to upgrade it, to much pressure (fpr), i dont think the spring can handle it, i have a holley 195 fuel pump?
Modified by gogou99 at 12:15 AM 10/16/2003
Old Oct 15, 2003 | 03:16 PM
gogou99's Avatar
ttt
Old Oct 16, 2003 | 10:56 AM
either aem regulator with the holley, or stock pump and stock reg.
QUICKwitit
Feb 10, 2008 04:51 AM
fieromadman
Apr 29, 2006 06:37 PM
IloveAPC
Oct 26, 2004 07:14 PM
