problem with boging when first crank when not been cranked in few hours
Old Oct 14, 2003 | 04:33 PM
Wilson C.'s Avatar
Default problem with boging when first crank when not been cranked in few hours
My car bogs when i first crank it. If i crank it and drive until it gets warm it dont bog as bad. What could this be? I have a b16a in a 90 model civic.
Old Oct 14, 2003 | 04:39 PM
mmuller's Avatar
Mad Scientist
Default Re: problem with boging when first crank when not been cranked in few hours (Wilson C.)
maybe running rich on open loop mode. what kind of ecu?
Old Oct 14, 2003 | 04:45 PM
Wilson C.'s Avatar
Default Re: problem with boging when first crank when not been cranked in few hours (mmuller)
have a pr3 ecu converted from auto to manual OB0
Old Oct 15, 2003 | 06:26 PM
leadfoot78's Avatar
U might have a bad IACV selenoid, clean it and try it also try opening the idle screw a little more and see what it does. Also when car is idling unplug the IACV and listen for changes in rpm if it doesnt change it might be broken or clloged. It might be also fuel like posted above and it might be a few other things.
88crxdxfastwhip
Aug 31, 2005 11:24 AM
jetpilot
May 24, 2004 05:50 AM
