supercharger question
Old Oct 14, 2003 | 03:26 PM
WuRKD b16's Avatar
Default supercharger question
I have a 89 siR motor. I have crower st 2 cams, full crower valvetrain, ctr pistons with totalseal gapless rings, milled head, spoon headgasket and all the bolt ons (mani, CAI..) producing 180hp & 116tq @ the wheels. i drive my car a lot a long distance to skoo, so i was wondering if the JR supercharger would be a good choice. I know i went hi-compression all motor setup but i'm not satisfied with the power and i feel like its a waste of money if i put my car back to normal to run the SC. Would my current setup with the SC be too much on my motor. Would it run safe with hi-compression? I want something reliable enough to drive everyday and have power.
Old Oct 14, 2003 | 07:10 PM
solo2slocivic's Avatar
will work fine just dont go crazy with the boost... max about 4 to 5 psi...
installed a jr charger on a prelude sh last yaer and it runs 9psi on stock motor kick *** fun to drive
Old Oct 14, 2003 | 07:48 PM
WuRKD b16's Avatar
Default Re: (solo2slocivic)
so you dont think my all motor setup wouldnt cause problems after adding the JR SC, and buying a used SC is that a good idea? What are some things i should take into consideration about goin with da SC. Are there things i should get maybe a thicker headgasket instead?
Old Oct 14, 2003 | 08:46 PM
be careful of used sc's... you could drop compression a little if u want to run more boost but personaly i would leave the motor as is and limit the amount of boost..... one big consideration that u need to adress is ignition timing you will need to use a boost retard system to give u quick adjustability against detonation... and if u havent done it yet u should install a mugen t-stat and fan switch...lower combustion temps = less timing retard required..
u have the makings of a very fun setup
Old Oct 15, 2003 | 02:26 PM
WuRKD b16's Avatar
koo thanks a lot for your help. it seems as tho no one like to respond to my posts, but you did so thanks a lot.
Old Oct 15, 2003 | 09:42 PM
any time
Old Oct 15, 2003 | 10:25 PM
mmuller's Avatar
Mad Scientist
about 11.1 comp. and milled head; how much? + boost. mmmhhh, maybe i would get a thicker headgasket and defenetely a good tunning device like hondata.
I4BangN
Sep 7, 2008 09:39 AM
romero4
Feb 13, 2007 05:29 PM
integrakilla
Nov 28, 2004 06:23 PM
BME1986
Nov 4, 2003 05:48 PM
jmcfkya
Apr 13, 2003 02:59 PM
