Can somebody help me step by step.....
There is an oil line in the back of the block, towards the firewall, that you have to have special fitting to use to tap into it. You put the fittings into the block, that tee off into the oil line, and you connect the standard like back to the fittings. You then run that line to the sender, and the wires from the sender to the gauge.
gmoore
gmoore
You also have the option of using a metric-to-pipe bushing that GReddy sells. It allows the 1/8" NPT oil temperature sending unit to be threaded into the pipe bushing which threads into the oil pan drain.
The way I'm doing it is sticking the oil temp and pressure sending units into a remote filter head in the oil cooler/remote filter system.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chemicalviper »</TD></TR><TR><TD CLASS="quote">What about electric oil press gauge ...</TD></TR></TABLE>
See above diagram.
See above diagram.
egzo04
Sep 4, 2006 09:14 PM
SPOON_BeIgHtEeNsEe
Mar 4, 2002 05:24 PM
