Electrical help
Old Oct 14, 2003 | 01:23 PM
CivicBoi's Avatar
Default Electrical help
My '90 Rex is on the fritz.... a week ago battery just drained for no apperent reason got it boosted and it started fine.... waited about a week to grab a new battery..(strapped for cash).. When i placed the new battery ...car won't even crank... interior light doesn't work.. completely no power... the only thing that works is the hazard lights...
Need help... please... please..
Old Oct 15, 2003 | 08:48 AM
CivicBoi's Avatar
Default Re: Electrical help (crxboi)
bump
Old Oct 15, 2003 | 08:51 AM
spaceman's Avatar
check your alternator,ground connections,fuses..check all your electrical connections while your at it make sure everything is connected properly..good luck
Old Oct 15, 2003 | 10:17 AM
CivicBoi's Avatar
Default Re: Electrical help (spaceman)
If you're main relay goes will this happen?
Thanks..
Old Oct 15, 2003 | 11:11 AM
FourthGenHatch's Avatar
Your Main Relay only makes the fuel pump not turn on. Everything else in the car should work.
Check your fuses first, you maybe have done something to fry a bunch of them. Don't forget the ones that are in the box under to hood also, there is one in there for ignition I believe.
If you give me a list of things that don't work after you've check what everyone told you, I may be able to help you find your problem. I take a course in Electrical Diagnosis in school and will have a Toyota certification soon enough, and an ASE one eventually. So I may be able to help you find if a wire or something got fried.
NotAJDMFanBoy
Apr 21, 2020 08:21 PM
articsilber323
Sep 18, 2009 10:07 PM
90hatchblack
Nov 10, 2007 03:33 PM
hurraquio
Feb 4, 2006 07:34 PM
blks2k3
Apr 10, 2005 08:01 AM
