Turbo my d16z6???...
Old Oct 14, 2003 | 11:19 AM
jdmCivic925's Avatar
Default Turbo my d16z6???...
sup,...im trying to turb my d16z6....can i use my stock piston and turbo it???....
Old Oct 14, 2003 | 11:26 AM
careawholelot's Avatar
Default Re: Turbo my d16z6???... (delsol925)
yes u can
eg6beater's Avatar
yea i guess....wont last very long..ven if you keep it at low boost pressures.....z6 bottom ends are not made to handle much more compression or abuse...you can joy ride for a while until the rings give out, snap a connecting rod...destroy a piston..ect. if you want longer lasting and safe boosting...built your bottom end first.
Old Oct 14, 2003 | 11:53 AM
ladysman's Avatar
Default Re: Turbo my d16z6???... (eg6beater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6beater &raquo;</TD></TR><TR><TD CLASS="quote">yea i guess....wont last very long..ven if you keep it at low boost pressures.....z6 bottom ends are not made to handle much more compression or abuse...you can joy ride for a while until the rings give out, snap a connecting rod...destroy a piston..ect. if you want longer lasting and safe boosting...built your bottom end first.</TD></TR></TABLE>
I have been boosting my Z6 (stock block) for almost 4 years now. The last year it has seen 10psi+ daily. The motors can hold their own IF they are properly tuned. Mine was tuned on Hondata by myself.
Old Oct 14, 2003 | 11:56 AM
silverEH2's Avatar
wrong.......please do not misinform people
Old Oct 14, 2003 | 08:03 PM
eg6beater's Avatar
Default Re: Turbo my d16z6???... (careawholelot)
sorry i dunno anything...i ride a schwinn
Old Oct 14, 2003 | 08:07 PM
Tad's Avatar
Tad
Default Re: Turbo my d16z6???... (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">
I have been boosting my Z6 (stock block) for almost 4 years now. The last year it has seen 10psi+ daily. The motors can hold their own IF they are properly tuned. Mine was tuned on Hondata by myself.</TD></TR></TABLE>
impressive,
but that IS on the better side of things.
10psi daily is a bit much on a stock d16.
i'd say 6-7psi will definetely last plenty long.
not everyone can afford hondata afterall.
Old Oct 14, 2003 | 08:10 PM
5thgen's Avatar
Default Re: Turbo my d16z6???... (Tad)
10 psi is fine on a d16......I've been running 10 pounds for 2 1/4 years.....57,000 miles, From 115,000 to 172,000
Old Oct 14, 2003 | 09:26 PM
have u ever run ur car in 1/4 mile track??...what u run???
Old Oct 14, 2003 | 09:48 PM
5thgen's Avatar
Default Re: (delsol925)
avg 13.8-13.9
best 13.73 @ 102.83
Old Oct 14, 2003 | 09:59 PM
Can you tell me what u done to ur engine...???
Old Oct 14, 2003 | 10:08 PM
Neptune's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsol925 &raquo;</TD></TR><TR><TD CLASS="quote">Can you tell me what u done to ur engine...???</TD></TR></TABLE>
With any decent turbo set up you should be running these times easily.
Old Oct 14, 2003 | 10:55 PM
13BT's Avatar
how is highway driving with the turbo? any negative affects?
Old Oct 27, 2003 | 09:50 AM
al3e's Avatar
blah blah im bored
Old Oct 27, 2003 | 10:02 AM
DjFreeze's Avatar
Default Re: Turbo my d16z6???... (al3e)
im actually gonna be turbo'n mine , should have it in, in about 1 month... but my idea was to just turbo it now on stock internals, buy another bottom end or a d16z6 for that matter(since there dirt cheap), rebuild it and then switch. and you will still have an extra just incase something happened
Old Oct 27, 2003 | 10:43 AM
blackeg's Avatar
Default Re: Turbo my d16z6???... (DjFreeze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DjFreeze &raquo;</TD></TR><TR><TD CLASS="quote">im actually gonna be turbo'n mine , should have it in, in about 1 month... but my idea was to just turbo it now on stock internals, buy another bottom end or a d16z6 for that matter(since there dirt cheap), rebuild it and then switch. and you will still have an extra just incase something happened</TD></TR></TABLE>
good plan i would do this if i were to turbo.
Old Oct 27, 2003 | 11:18 AM
Cee_mon's Avatar
Default Re: Turbo my d16z6???... (blackeg)
already doing that plan.....^
boosted D16 at 8psi and picking up a D16 next weekend
Old Oct 27, 2003 | 11:34 AM
civic_tuned's Avatar
Default Re: (5thgen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgen &raquo;</TD></TR><TR><TD CLASS="quote">avg 13.8-13.9
best 13.73 @ 102.83</TD></TR></TABLE>
do u own a hatch or coupe. can coupes hit 13's also w/ just a turbo
i have some car seats in the back and i hear is daddy go faster!
Old Oct 27, 2003 | 12:26 PM
D-t's Avatar
D-t
What turbo, and ratios are you using , plus management?
Thanks. I'm trying to basically get a z6 turbocharged with not much done to it, a simple good setup with afc hack plus bigger injectors into 12's daily driven. I use to hate d-series or sohc's for that matter. Now turbochargin them pretty much stock and them being quick, has made me seen the light. Cheap, at least then a stock b series or H stock. fast, and pretty much reliable if you take care of them, tuning, etc.
Old Oct 28, 2003 | 05:38 PM
5thgen's Avatar
Default Re: (VeLoXHaTcH)
motor is completely stock.....its a 94 ex coupe....hopefully in a hatch (cx/vx) it would yeild high 12s with a lot of grip.
I'm using a greddy 15g kit right now, 10-9 psi on the blue box....stock fuel system except for a holley/walbro fuel pump.
Old Oct 28, 2003 | 05:46 PM
shermanyang's Avatar
Default Re: Turbo my d16z6???... (5thgen)
you can boost stock bottom block safely up to 15 psi daily/well tuned/intercooled/larger injectors. i've seen a lot of people accomplish this already. the life of your motor no matter how many lbs you're running all depends on your driving habits. you could boost only 6 psi daily and be a nut of a driver and blow your rings/motor within a few months. or you could boost 15 psi daily and be conservative driver and have your motor last for years. just my .02
Old Oct 28, 2003 | 08:55 PM
al3e's Avatar
yes you can... but wont last long.....
Old Nov 6, 2003 | 09:25 PM
delsolb18's Avatar
Default Re: Turbo my d16z6???... (delsolb18c1)
sold
Old Nov 6, 2003 | 10:06 PM
chillly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by al3e &raquo;</TD></TR><TR><TD CLASS="quote">yes you can... but wont last long.....</TD></TR></TABLE>
...if your tuning sucks...
While it's not really debatable that the D16's not as robust as a B series, as long as you're tuning is good and you don't get too greedy with the boost, there's no reason why it can't be fairly reliable..
Just my $0.02 worth
Old Nov 6, 2003 | 11:21 PM
mycivicstoo(s)low's Avatar
Default Re: Turbo my d16z6???... (delsolb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsolb18 &raquo;</TD></TR><TR><TD CLASS="quote">sold
</TD></TR></TABLE>What the hell? Great first post, tard.
