T3/T04e Vs SC61
Old Oct 14, 2003 | 10:02 AM
Ri5e's Avatar
Default T3/T04e Vs SC61
I did a search already using 60-1 but for some reason the search bot will not search for it.
Currently I have T3/T04e (.60 a/r compressor, .63 a/r exhaust) with a 60 trim and stage 3 wheel in the exhaust housing.
I'm still waiting for my Lovefab Sidewinder manifold so I have time to switch turbos.
I'm running a 1.8 LS and aiming to run 13-14 LBs daily(street driven) and I want something that will make that amount of boost around 5,000-5,500 RPM. It also want it big enough so that I can put race fuel in it, crank the boost up for Track and make some good power.
Should I stick with my current turbo or switch to a SC61 with .60 a/r compressor housing, .63 a/r exhaust housing. I'm not sure if I should get the 69 trim or 76 trim exhaust wheel??
I'm not sure if switching to precision sc61 will make much of a difference since i'm staying 13-14 psi on the street
Also, anyone in here have the measurements for the exducer and inducer for the wheels on the t3/t04e
Old Oct 14, 2003 | 11:24 AM
TurboTegB18c's Avatar
Default Re: T3/T04e Vs SC61 (CRV Monster)
Ur turbo you currently have is probably better for 13-14 psi. I'm running the sc61 on 1.97L block and get 15psi at 5500rpm.
You can still put in race gas and boost 20+ psi on that turbo that you have.
Old Oct 14, 2003 | 11:30 AM
Ri5e's Avatar
Default Re: T3/T04e Vs SC61 (TurboTegB18c)
But power wise, how would they compare with the same boost setting? I heard the SC61 gives you much more of a "boost" / top end
Old Oct 14, 2003 | 11:34 AM
InTeGrA B18b1's Avatar
i think that the sc61 flows more cfm at the same boost level as t3/t4 and spools a little faster than it too.
Old Oct 14, 2003 | 11:46 AM
Ri5e's Avatar
Default Re: T3/T04e Vs SC61 (InTeGrA B18b1)
you "think"?
Old Oct 14, 2003 | 11:48 AM
chidoks's Avatar
an Sc61 outflows a t3/t04e
Modified by chidoks at 10:37 PM 10/14/2003
Old Oct 14, 2003 | 01:23 PM
FredoSP's Avatar
Default Re: T3/T04e Vs SC61 (chidoks)
the SC61 compressor wheel is the new GT wheel, which are very efficient
Old Oct 14, 2003 | 01:24 PM
BodyKits NW's Avatar
Default Re: T3/T04e Vs SC61 (FredoSP)
Stick with what ya got. You will make good power with that turbo in that psi range.
Old Oct 14, 2003 | 02:01 PM
Finest's Avatar
Default Re: T3/T04e Vs SC61 (BodyKits NW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BodyKits NW &raquo;</TD></TR><TR><TD CLASS="quote">Stick with what ya got. You will make good power with that turbo in that psi range. </TD></TR></TABLE>
K.I.S.S.
Why drop another $1000+ on a turbo that's "slightly" better than what you have (or ever will need, really). The SC61 is a bada$$ turbo, no doubt...but if you have a decent sized turbo like yours, there's no reason to "upgrade" until you finish your turbo setup now and get it tuned and running. AFTERWARDS, if you feel that it's not enough, then that's where you get into the fancy smancy ball-bearing stuff.
Old Oct 14, 2003 | 11:09 PM
Ri5e's Avatar
Default Re: T3/T04e Vs SC61 (98CTRCoupe)
sounds good guys, looks like i'll just keep what i have, thanks
before i polished and after
Old Oct 14, 2003 | 11:22 PM
MRSI00's Avatar
Is the SC61 too big for a 1.6L b16?
Old Oct 14, 2003 | 11:30 PM
twkdCD595's Avatar
what compound or media did you use to polish the housing ?
Old Oct 15, 2003 | 05:45 AM
COOKIEPUSS's Avatar
Default Re: T3/T04e Vs SC61 (MRSI00)
Someone here got goood numbers w/ an SC61 on a bone stock B16, and I think it spooled around 5500.
Old Dec 31, 2003 | 07:01 AM
Ri5e's Avatar
Default Re: T3/T04e Vs SC61 (twkdCD595)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">what compound or media did you use to polish the housing ?</TD></TR></TABLE>
red rouge
Old Dec 31, 2003 | 07:51 AM
VTC_CiViC's Avatar
Default Re: T3/T04e Vs SC61 (BG Boost)
Funny this post is brought up, I have the identical turbo (T3/T04E 60-trim, .60/.63) and I too am looking to trade it out for an SC61 with the 69mm wheel. I do however have a GS-R (8k+) vs. an LS limited to 7k rpm so I have more room to flex the turbo on the top side. For an LS I *think* I'd probably reconsider and keep the T04E.
Old Dec 31, 2003 | 09:19 AM
PM-Performance's Avatar
Default Re: T3/T04e Vs SC61 (VTC_CiViC)
i got the same turbo ,but i got the 82 ex housing , im hoping it will get me decent numbers, but im looking at the t67 if this one fails to impress me at higher levels.
the thing breathes like crazy on top end though. pulls hard, but i didnt thro w alot of boost at it yet.
Old Jan 3, 2004 | 11:02 AM
Ri5e's Avatar
Default Re: T3/T04e Vs SC61 (itr206)
Oh, that turbo is just my "Back Up Turbo" now ...
I've decided to get a T67/T3.
Going All out now with a 2.0 Liter VTEC
Old Jan 3, 2004 | 11:25 AM
94gsr4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BG Boost &raquo;</TD></TR><TR><TD CLASS="quote">Oh, that turbo is just my "Back Up Turbo" now ...
Going All out now with a 2.0 Liter VTEC </TD></TR></TABLE>
Thats what i decided on too, but still on an 81mm gsr block
Casey
Dec 28, 2011 08:06 PM
zaccers
Apr 6, 2010 02:41 PM
gawath
Dec 22, 2006 08:36 AM
JalopySiR
Feb 7, 2003 06:48 PM
B20bTurbo
May 8, 2002 10:11 PM
