Do I have a bad Pr3 ECU?
Old Oct 14, 2003 | 08:44 AM
B18aTegra's Avatar
Default Do I have a bad Pr3 ECU?
I Did a B16a swap into a 91Ls used the Ls harness on the B16a. wired up VTEC, plugged in Pr3 ECU and I get no fuel. I think I may have been sent a bad ECU. I plug the pr4 ecu back in and the b16a fires right up. I know this seems like a no brainer but I want to make sure. I'm pretty sure its bad, I just want to make sure I didn't over look anything. The wires I ran in are knock, 2nd o2, VTEC oil press, VTEC solenoid. Did I miss anything?
Thanks
Josh
Old Oct 14, 2003 | 09:03 AM
Full Race EG's Avatar
Default Re: Do I have a bad Pr3 ECU? (B18aTegra)
yep sounds like your ecu is bad. did the car have any CEL's?
Old Oct 14, 2003 | 10:42 AM
B18aTegra's Avatar
Default Re: Do I have a bad Pr3 ECU? (IntegraLStuner)
Well the CEL lights up on the dash as normal, when you turn the key on. But the ECU itself does nothing, since its OBD0 the LED inside the ECU is supposed to light up and give codes. But This ECU does nothing inside!
Josh
Old Oct 15, 2003 | 06:27 AM
Xsi's Avatar
Xsi
Does the led flash once when the ignition is turned on? if not, it's faulty.
Old Oct 15, 2003 | 06:45 AM
B18aTegra's Avatar
No it didn't do anything! So that one falsh is normal? I switched it out with another PR3 and she fired right up. But I was checking to see if it was throwing any codes and I got the one flash so I though I may of had a o2 problem! Thanks again
Josh
P.S. is that your XSI on that website?
Old Oct 15, 2003 | 06:55 AM
Xsi's Avatar
Xsi
Yep, thats my XSi
If one ECU starts it up and another doesn't, thats never good
Old Oct 15, 2003 | 07:10 AM
B18aTegra's Avatar
nice work on the Xsi..nice write up BTW! I enjoyed reading it. But you don't like the cams? can you elaborate?
Old Oct 15, 2003 | 04:57 PM
Xsi's Avatar
Xsi
I know they'll make power once tuned properly, but everyone seemed to rave about their 'drop in' power which I didn't experience at all.
I'm just waiting until I het my new head and intake manifold on before I spend on proper tuning.
bara6075
Feb 19, 2008 04:22 PM
c_buz
Feb 6, 2005 12:59 PM
Hybridize
25
Oct 30, 2003 03:11 AM
GeeSeeR
Sep 18, 2001 06:30 PM
