Winter Preperations
if your gonna drive it, change the oil before winter... I cant remember if you want to run thicker or thinner oil... I want to say thinner oil, because you want to run thicker oil in the summer so it doesnt break down in the heat as easily...
Also, make sure you have a good mix of antifreeze..
Check the car over for any routine maintenance it needs... better off to do it now than when its 10 degrees outside...
Also, put a few coats of wax on the car...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScrapinSi »</TD></TR><TR><TD CLASS="quote">if your gonna drive it, change the oil before winter... I cant remember if you want to run thicker or thinner oil... I want to say thinner oil, because you want to run thicker oil in the summer so it doesnt break down in the heat as easily...
Also, put a few coats of wax on the car... </TD></TR></TABLE>
indeed everything ScrapinSi said is true... and its thinner as the oil need to get up in the motor......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">change to winter air in the tires
hehehe... you should see the look on people's faces at my girl's gas station when people ask for air in their tires, and you ask if they want the winter air or the summer air.. They give you this dumfounded look like a deer in the headlights... Or this one guy says "Yeah, its about that time of year, put the winter air in that one tire for now, and i'll come back to get the rest changed in a week or 2"
I just laughed and put the air in...
Also, like was stated, check your wiper blades. Also clean your undercarraige good... That way its less you'll have to clean off in the spring after all the salt gets up in there... If you have any exposed metal parts from rubbing or scraping, clean them and paint them with rubberized undercoating...
what would be the downside with driving a car thats lowered 2 inches? Other then the fact that it might become a "snow plower" like someone here in the board mentioned to me? any other conerncs that i should have?
I drove my car lowered 3+ inches in the snow.. its all about where you want to go and how good you can handle your car...
My civic sits in the winter now and I drive my neon...
My neon goes ANYWHERE in the snow...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by careawholelot »</TD></TR><TR><TD CLASS="quote">remember to change your blinker fluid, i always forget to do this
Gay...serioulsy though...eveyone else's suggestions have been valid. (With the exception of the winter air, but that made me laugh). Definately slap the steelies/all seasons back on. Other than that, back to thinner oil and make sure that you have a good antifreeze mix.
</TD></TR></TABLE>Gay...serioulsy though...eveyone else's suggestions have been valid. (With the exception of the winter air, but that made me laugh). Definately slap the steelies/all seasons back on. Other than that, back to thinner oil and make sure that you have a good antifreeze mix.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">oh...maybe remove your front lip (if you have one)...snow is heavy (duh) and it might rip the lip off if youre low enough for it to be a plow</TD></TR></TABLE>
Or leave it on and make money like i did plowing driveways... LOL!
maybe if yout get one of those tsunami lips...massive things...theyre angular too so it might work great!
</TD></TR></TABLE>maybe if yout get one of those tsunami lips...massive things...theyre angular too so it might work great!
george34
24
Sep 10, 2006 06:51 PM
