Think I got ripped on ITR cams
Old Oct 14, 2003 | 07:03 AM
DocV's Avatar
Default Think I got ripped on ITR cams
Heres the webpage of what they look like. I got them from Ebay from somebody w/ 99% seller rate. http://hometown.aol.com/vtecnit01/index.html these are the pics of the cams. Here the link to the ebay auction. I really think there gsr cams b/c there's no grooves on the distributor side of the cams. Thanks for you help
http://cgi.ebay.com/ebaymotors...&rd=1
Old Oct 14, 2003 | 07:06 AM
rsbad454's Avatar
Default Re: Think I got ripped on ITR cams (VtecNit2k1)
do they have to have the grooves...........?
Old Oct 14, 2003 | 07:19 AM
DocV's Avatar
Default Re: Think I got ripped on ITR cams (rsbad454)
not at all as you can see in the pics that's Y i think there gs-r or b16a
Old Oct 14, 2003 | 08:06 AM
rsbad454's Avatar
only way is to measure lobes, and or use a Dial indicator to measure vavle lift when installed.
Old Oct 14, 2003 | 08:07 AM
sleepyEK's Avatar
if there are no grooves they are not TR. why did you buy them if they didn't have the grooves?
Old Oct 14, 2003 | 08:19 AM
coneheadsracing's Avatar
Default Re: Think I got ripped on ITR cams (sleepyEK)
The boxes are the right part numbers
http://asian_e.tripod.com/Honda_Engine_Specs.htm *bottom of the page*
Old Oct 14, 2003 | 10:31 AM
DocV's Avatar
Default Re: Think I got ripped on ITR cams (coneheadsracing)
b/c you couldn't see the pic but the part number are itrs
Old Oct 14, 2003 | 11:09 AM
Katman's Avatar
those seller's pictures totally SUCK (blurrrrry)......got damn it.... why don't people use the freakin MACRO button when taking close-up pics??!?!?
it's boggled my mind for quite sometime now..
I'd give you some input, but the owner's pictures suck too bad. I can't really tell wuts up with those cams...
although my tech pics are rather nice eh? haha...
...here's an updated pic of a CTR intake cam:
89-91 b16a cams:
....isn't the macro setting uber cool?
Old Oct 14, 2003 | 11:39 AM
DocV's Avatar
Default Re: Think I got ripped on ITR cams (Katman)
yo those are phat pics Katman now I can totally see that dshish2002@yahoo.com is a poser even though he has high feedback. thanks Kat
Old Oct 14, 2003 | 11:49 AM
temp's Avatar
and what if they are the 97-98 ITR cams? would they have those groves as well?
Old Oct 14, 2003 | 12:02 PM
turboxsi's Avatar
Default Re: Think I got ripped on ITR cams (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">and what if they are the 97-98 ITR cams? would they have those groves as well?</TD></TR></TABLE>
Yes there is a single groove at base of cam on dizzy side of intake cam.
Old Oct 14, 2003 | 12:04 PM
temp's Avatar
Default Re: Think I got ripped on ITR cams (turboxsi)
thanks, and what if they are the 96 JDM spec itr cams? anyone know about those?
Old Oct 14, 2003 | 01:05 PM
Highrevs99's Avatar
I had a 97 JDM ITR motor and changed the cams , well I noticed no grooves . The only way you will tell is to mic the cams . You probably have old JDM ITR cams which means the intake has 3 deg. less duration .
Old Oct 14, 2003 | 01:17 PM
temp's Avatar
Default Re: Think I got ripped on ITR cams (Highrevs99)
thats what i thought and thats why i asked the questions i did
Old Oct 14, 2003 | 01:24 PM
SimbaDogg's Avatar
hope u didn't get ripped off...that sucks
Old Oct 14, 2003 | 01:36 PM
turboxsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Highrevs99 &raquo;</TD></TR><TR><TD CLASS="quote"> I had a 97 JDM ITR motor and changed the cams , well I noticed no grooves . The only way you will tell is to mic the cams . You probably have old JDM ITR cams which means the intake has 3 deg. less duration . </TD></TR></TABLE>
http://hometown.aol.com/vtecnit01/index.html-- Look at the pics at the bottom of this website, the cam on the left is marked (95-00 JDM ITR; USDM 97-99). There is a groove at the base of the dizzy connection.
Old Oct 14, 2003 | 01:51 PM
egg's Avatar
egg
hopefully you didnt get ripped off but if you do, how did you pay?
if by credit card then contact the cradiet card company.
Old Oct 14, 2003 | 01:52 PM
turboxsi's Avatar
http://hometown.aol.com/vtecnit01/index.html-- Look at the pics at the bottom of this website, the cam on the left is marked (95-00 JDM ITR; USDM 97-99). There is a single groove at the base of the dizzy connection.
Sorrry don't know how this got posted twice!!!
Katman's Avatar
JDM 95-98 & US 97-98 ITR cam markings are seen in the very first image in this diagram (single engraved ring w/2 protruding outter edged rings):
(i need to update the dates on this diagram, there were no 99 US ITR's)
...it could be a little tricky with the single engraved ring'd cams, cuz there are other non-Type R cams that have singled engraved rings too, as seen here on this B17A int.cam:
...in this case, you want to keep an eye on the bigger ring's markings, as stated in my image.
Old Oct 14, 2003 | 02:06 PM
temp's Avatar
thank you
Old Oct 14, 2003 | 05:06 PM
PHiZ's Avatar
Nobody rocks like katman rocks!
-PHiZ
Old Oct 14, 2003 | 09:46 PM
That Dood's Avatar
tgo put them in and see when you feel vtec start to pull and fell aorund 7800 and feel for it...if they pull harder then they are. You can easily tell your using ITrs of GSR or B16A2 cams.
Old Oct 14, 2003 | 10:39 PM
PHiZ's Avatar
Default Re: Think I got ripped on ITR cams (That Dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by That Dood &raquo;</TD></TR><TR><TD CLASS="quote">tgo put them in and see when you feel vtec start to pull and fell aorund 7800 and feel for it...if they pull harder then they are. You can easily tell your using ITrs of GSR or B16A2 cams.</TD></TR></TABLE>
Much better idea than all that factually correct, well researched, fully illustrated bullshit katman was spouting.
-PHiZ
Old Oct 14, 2003 | 10:46 PM
SimbaDogg's Avatar
Default Re: Think I got ripped on ITR cams (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">
-PHiZ</TD></TR></TABLE>
yeah...if you can't tell visually which cams you have after looking @ them in the pictures...why not bolt em in your car and use the butt dyno to decide whether you have itr/ctr/gsr/b16 1st gen cams.. :rollseyes:
Old Oct 15, 2003 | 06:18 AM
turboxsi's Avatar
Default Re: Think I got ripped on ITR cams (SimbaDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SimbaDogg &raquo;</TD></TR><TR><TD CLASS="quote">
Or instead of wasting your time to put in non-TR cams. YOU can tell by matching them to Katmans pics!
