TLC for your motor
Old Oct 14, 2003 | 05:47 AM
quickls's Avatar
Default TLC for your motor
What do you guys use to clean your motor? What kind of special cleaning solutions, or anything like that... Um right now im doing my swap and its sitting in my garage so its pretty dirty, i need some ideas to clean it... thanks in advance
Old Oct 14, 2003 | 05:55 AM
P1mpSlap's Avatar
simple green and an engine degreaser
Old Oct 14, 2003 | 05:59 AM
mathusala's Avatar
Default Re: TLC for your motor (quickls)
some people use gasoline
I use mineral spirits or if I'm feeling particularly cheap, paint thinner (made from mineral spirits). a practical order of 'solventness' would be gasoline, varsol, mineral spirits, paint thinner - they're pretty-much the same except for the amount of refining. none of it is biodegradable, the bio stuff doesn't work. you can get it by the gallon from Home Depot.
good luck
Old Oct 14, 2003 | 06:15 AM
quickls's Avatar
tell me more about these minerals spirts, how do i apply them, do i use a rag, what part of the motor do i clean w/ mineral spirits?
Old Oct 14, 2003 | 06:50 AM
wickedEFguy's Avatar
Simple green, soap, tooth brush, GUNK degreaser, and water............If you take your time you can make anything look nice
Old Oct 14, 2003 | 07:18 AM
mathusala's Avatar
Default Re: (quickls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quickls &raquo;</TD></TR><TR><TD CLASS="quote">tell me more about these minerals spirts, how do i apply them, do i use a rag, what part of the motor do i clean w/ mineral spirits?</TD></TR></TABLE>
it's just like using gasoline (it evaporates and leaves the same kind of residue) but not nearly as smelly or flamable. when you're through with it, use the dregs to rinse your oil-change pan, pour it back into the original can and take it to autozone for disposal.
whiteEGlsvtec
Paint and Body
Jul 11, 2007 05:36 PM
HondamanXxX
46
May 28, 2007 02:57 PM
Serdar
10
Nov 20, 2006 11:40 AM
wm5holla
Feb 4, 2003 06:26 PM
MikeBibby
Aug 14, 2002 08:25 AM
