why did you put turbo?
Old Oct 14, 2003 | 05:09 AM
ggangtong81's Avatar
Default why did you put turbo?
for those people with turbo, why did u put turbo into your car??
just curious. already put on FI, but no response. so just wanna know. thanks.
Old Oct 14, 2003 | 05:28 AM
xx dc2teg xx's Avatar
Default Re: why did you put turbo? (ggangtong81)
dude, most likely to go fast
P1mpSlap's Avatar
b/c I like the sound of the BOV
Old Oct 14, 2003 | 06:54 AM
IMPATIENT's Avatar
Default Re: (P1mpSlap)
because its alot easier and alot cheaper to make 250 hp on a stock motor than spending *** loads on building an all motor setup to make less.......
Old Oct 14, 2003 | 07:01 AM
joshmarlette's Avatar
Default Re: (IMPATIENT)
Turbo question... If I wanted to get a turbo for my 95 RS, would I need to change internals or anything ?
Old Oct 14, 2003 | 07:11 AM
Default Re: (joshmarlette)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joshmarlette &raquo;</TD></TR><TR><TD CLASS="quote">Turbo question... If I wanted to get a turbo for my 95 RS, would I need to change internals or anything ?</TD></TR></TABLE>
as far as i know, if you run low psi, you don't need to change any internals. run like 6 to 7 psi, and you should be fine with any kit.
Old Oct 14, 2003 | 07:19 AM
gh0st32's Avatar
Default Re: (ggangtong81)
yeah you'll be fine if you keep the boost low ,&lt;=8 psi
Old Oct 14, 2003 | 10:02 AM
StatGSR's Avatar
Default Re: (gh0st32)
yea, i even hear u can run 11psi on stock B18B internals, so you should be safe around 8.
Old Oct 14, 2003 | 10:07 AM
gh0st32's Avatar
Default Re: (orange_civic)
just as long as you have an intercooler but 11 psi does seem too high on stock internals. I guess if you really know what you are doing with the fuel set up and **** you might be allright
Old Oct 14, 2003 | 10:52 AM
quikB18B's Avatar
Guys it depends on the fuel setup, its all about the fuel.
stock b18b has been proven to hold thier own. There are plenty of people making close to 300 whp on stock ls block. Espanol just made over 300 whp, on stock ls. He has alos been running high boost for quite some time now, no probs whatsoever.
Properly tuned the ls block can handle alot of boost nuff said.
Im running 8 psi for now because im still on fmu setup , but once i get my hondata im going to tune to 12 psi
Old Oct 14, 2003 | 11:01 AM
Hybrid Invasion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPATIENT &raquo;</TD></TR><TR><TD CLASS="quote">because its alot easier and alot cheaper to make 250 hp on a stock motor than spending *** loads on building an all motor setup to make less.......</TD></TR></TABLE>you know man, there's really no need for any further explanation than this.
Old Oct 14, 2003 | 09:44 PM
Shadow Racer's Avatar
is a motor build and boost a good combo? as long as you tune it and all. what i mean is, does it work well?
Old Oct 14, 2003 | 10:05 PM
CNSK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ggangtong81 &raquo;</TD></TR><TR><TD CLASS="quote">for those people with turbo, why did u put turbo into your car??
just curious. already put on FI, but no response. so just wanna know. thanks. </TD></TR></TABLE>
To go faster no wonder you had no response in the Force induction...... waste of topic....
Old Oct 14, 2003 | 10:46 PM
Street_Kings's Avatar
My Old Civic:
Mugen Headers : 450.00
Mugen Exhaust : 450.00
AEM Cold Air Intake: 200.00
Total: 1100.00 Gain: 20 WHP
My New Teggy:
Custom Turbo Kit: 1500.00
Total: 1500.00 Gain: 150 WHP
Questions still?
Old Oct 15, 2003 | 01:00 AM
NuclearB18B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">b/c I like the sound of the BOV</TD></TR></TABLE>
haha
Old Oct 15, 2003 | 01:51 AM
JMod's Avatar
Default Re: (ha illuminato un)
There are bolt on turbo kits for the B18B's right? When you do get the certain kits, is it truely bolt on? What I mean is, you install the turbo kit, but does it require additional tuning in terms of your fuel and ecu?
Old Oct 15, 2003 | 03:30 AM
Doc_Honda's Avatar
Default Re: (BucsJosh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BucsJosh &raquo;</TD></TR><TR><TD CLASS="quote">There are bolt on turbo kits for the B18B's right? When you do get the certain kits, is it truely bolt on? What I mean is, you install the turbo kit, but does it require additional tuning in terms of your fuel and ecu?</TD></TR></TABLE>
Any turbo kit you install will basicly be bolt on. But as with anything else you do to your engine, there is no replacement for good tuning.
Old Oct 15, 2003 | 04:57 AM
gh0st32's Avatar
Default Re: (Doc_Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doc_Honda &raquo;</TD></TR><TR><TD CLASS="quote">
Any turbo kit you install will basicly be bolt on. But as with anything else you do to your engine, there is no replacement for good tuning.</TD></TR></TABLE>
Old Oct 15, 2003 | 05:33 AM
quikB18B's Avatar
Default Re: (Street_Kings)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Street_Kings &raquo;</TD></TR><TR><TD CLASS="quote">My Old Civic:
My New Teggy:
Questions still?</TD></TR></TABLE>
Thats why I laugh when people who are Na say they want to go turbo, but can't afford too, im like WTF. You don't have to spend 3,000 on a prefabbed kit, you can piece one together at your one financial pace, but hey what do I know
Old Oct 15, 2003 | 05:42 AM
YellowGiser's Avatar
Default Re: (quikB18B)
To keep up with V8's
Old Oct 15, 2003 | 06:45 AM
J-g-D-s-M-r's Avatar
boost &gt; vtec
BOV &gt; vtec
Old Oct 15, 2003 | 07:15 AM
patmcd's Avatar
Sure you can bolt that thing right up. But will it run well...probably not. There is not replacement for tuning when it comes to FI. You will make more power and have a more reliable setup.
Old Oct 15, 2003 | 07:16 AM
Dased530's Avatar
Default Re: why did you put turbo? (lDarkCloudl)
I was going to go turbo for the chicks
Old Oct 15, 2003 | 07:43 AM
m R g S r's Avatar
Default Re: why did you put turbo? (Dased530)
Because It's Fun!!!
Old Oct 15, 2003 | 08:10 AM
AspectIndustries's Avatar
Default Re: (YellowGiser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YellowGiser &raquo;</TD></TR><TR><TD CLASS="quote">To keep up with V8's </TD></TR></TABLE>
Keep up? To smoke up the V8 is what you want to say.
