Code 16...Help me out
Old Oct 14, 2003 | 12:18 AM
Magick211's Avatar
Default Code 16...Help me out
Ok im throwing a Code 16 wich is probally due to my main relay wich is bad. But what i want to know is do you think the code 16 has anything to do with my car bogging really bad? It will idle at about 1k then if i mash the gas while in neutral it will just bog really bad. Also has a good bit of smoke comming from the tail pipe. Someone let me know what you think
Old Oct 14, 2003 | 03:13 AM
USDM 4G VTEC's Avatar
Default Re: Code 16...Help me out (CivicBoyZC)
code 16 injector
if u have a bad injector its the cause of that code.
if ur injector its bad it might stay open and flood the cylinder wich causes the white smoke comming bad out of ur car... and also bogs the **** out of it
hgappened to me and find out what the problem was after even replacing the godamn headgasket....
anyways if u did MPFI recently go back to the injector wiring and check that all wiring its ok and not loose..... a fracture cable caused mines..... so make sure everytthings soldered, tight and nice
ExtraBlackRex
Oct 28, 2010 05:18 PM
red91hatch
Jun 6, 2008 06:23 AM
JaHnAbOi
Apr 6, 2007 01:20 PM
square_1
Apr 3, 2007 01:46 PM
civicrtype
Oct 27, 2002 01:28 PM
