High Fuel Pressure
Old Oct 13, 2003 | 10:50 PM
dominate9's Avatar
Default High Fuel Pressure
I just currently installed a turbo on my H22. I installed some DSM injectors. I'm having trouble starting my car. My fuel pressure gauge is reading way off the scale. It is reading over 100psi. What is my problem?
Old Oct 14, 2003 | 04:22 AM
JimBlake's Avatar
Default Re: High Fuel Pressure (dominate9)
Plugged return hose? Screwed up FPR?
Old Oct 14, 2003 | 09:07 AM
dominate9's Avatar
Default Re: High Fuel Pressure (JimBlake)
I don't know what it is. The pressure increased like that while the car was off. I think it occured while changing the injectors. The injectors are seated correctly, the FPR is fine, the lines are fine. Something happened during the injector installation. I don't know if I was supposed to remove the gauge or something before changing the injectors.
Old Oct 14, 2003 | 09:48 AM
Malgerus's Avatar
I know what the problem is... make sure that you have the washers in the fuel rail installed corectly!!!!! Raene screwed his up and had 75 psi of fuel pressure. fiddled with them and voila... down to 34 (stock).
the.hamburglar
Mar 27, 2015 07:58 AM
85
Jan 31, 2010 02:46 PM
ken2830
Nov 3, 2009 09:28 AM
ITRfaithful
Nov 2, 2003 06:15 PM
rbf351
Nov 27, 2002 07:28 AM
