Alternator Install
Old Oct 13, 2003 | 08:23 PM
95 GaNgStA AcCoRd's Avatar
Default Alternator Install
How hard is it to install an alternator? This isn't for my Accord, its for a 1991 Ninty Eight Recency Elite (Oldsmobile)
Old Oct 14, 2003 | 04:17 AM
JimBlake's Avatar
Default Re: Alternator Install (95 GaNgStA AcCoRd)
The alternator itself is easy to install. The PITA is whatever else you have to take off to get at the alternator. '89 Saab you have to remove the AC compressor. Some Hondas you have to remove an axle & take it out underneath. Some cars the alternator is right there & you just unbolt it...
Can't you just take a look under the hood of that car?...
Old Oct 14, 2003 | 06:18 AM
slow_dx's Avatar
Default Re: Alternator Install (JimBlake)
Yep,
I am 90% finished this job.
Had to remove the driveshaft to get it off. Probably have 6 hours in the job, but I'm a mechanical retard, and didn't know how this stuff worked. Next time would probably be around an hour.
My rebuilt alternator had a different adjuster bolt hole that the alternator that I took out, I'm going to try to pick up a new bolt at honda today and see if that fixes the problem... I'd recommend that you check your old hardware against the new alternator before you put it in there.
Old Oct 14, 2003 | 08:12 AM
sleepyEK's Avatar
Default Re: Alternator Install (slow_dx)
that alternator on the gm is so easy to do. it takes like 10 minutes literally. when i was with an independant i replace tons of them. easy money.
londonsupra
Jul 23, 2006 11:33 AM
Nandy
Honda Civic (2001 - 2005)
Jul 20, 2006 06:50 PM
firstgenrex
Oct 19, 2003 12:02 PM
