b16 problems
Old Oct 13, 2003 | 08:04 PM
TnC's Avatar
TnC
From: Sin City to CA, to TX, NC to FL, then back to NC...
Default b16 problems
i just installed my motor like i said in my last post on my vtec to ecu problems.. well i finally found out how to install it and a homie from hmo sent me the instructions and what i'm missing was my vtec oil pressure line and the vtec solenoid line. well now i just have a question about all you ef owners with a b16 swap.. okay here's my problem.. i don't have my vtec hooked up unfortunately and i drove it around a bit for the first time.. my exhaust is unbolted from the cat and on, and the first thing i noticed was my smog... too much black smoke.. grrr.. and when i tried flooring it from first gear, as soon as the rpms passed 3-4 thousand, my car bogs crazy.. so maybe i'm thinkin' too much fuel eh?? or could it be that my vtec isn't hooked up? or maybe i just need to break in my motor.. or is it because it's not corked... please reply to this asap!
Old Oct 13, 2003 | 08:56 PM
kylefakesi-r's Avatar
Default Re: b16 problems (SD91CRXsi)
get it all hooked up. run it for a while and drive it...it will clean out. the motors get a lot of **** in them sitting that needs to be run out
Old Oct 14, 2003 | 04:47 AM
ricodemus's Avatar
Default Re: b16 problems (kylefakesi-r)
it could be running rich due to not having the o2 sensors hooked up right, but I wouldn't worry about that black smoke yet. Who knows how long that poor motor sat around. I hope you changed all the fluids.
Old Oct 14, 2003 | 05:36 AM
Mr Furball's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kylefakesi-r &raquo;</TD></TR><TR><TD CLASS="quote">get it all hooked up. </TD></TR></TABLE>
Do this first, then get back to us. Too many things that COULD be the problem.
dirtyrice
May 25, 2007 03:31 PM
dump3deg6
Mar 24, 2007 03:19 AM
digitally_remastered
99
Jan 12, 2006 07:53 PM
hoya_10fintec
Feb 13, 2005 08:36 AM
ViXoN Hatch94
37
May 19, 2004 04:29 AM
