engine build-up ?'s
Old Oct 13, 2003 | 07:49 PM
delux247's Avatar
Default engine build-up ?'s
ok so here it is.
ive decided to build a c5 i have sitting around the house, but i have some questions on what im going to do and need some guidence in doing so.
i would like to run about 12:0-12:5 compression
eagle rods, acl bearings
i allready have a lsvtec thats about to take a ****, the head im using is a 2000 b16a with portflow headwork, jun valve train, toda spec c's and i will also be getting a valve job while the head is off
my questions are will i have to do any combustion chamber work with the compression i would like to run?
will i have to worry about the valves hitting pistons i was reading about deck clearance will i have to worry about that
any advice or tips are much appreciated
Old Oct 13, 2003 | 08:00 PM
1_bad_EF's Avatar
Default Re: engine build-up ?'s (egcivicturbo)
THe chamber should be polished if Tom set you up right. I thought that was part of it.
While your doing the vavle job, have em do the chambers if he didnt already.
As for Piston-valve clearance, I think that you need to talk to a piston manufacturer or wholesaler. Maybe talk to a well known shop for help ordering what you need.
I'm sorry that is all the help I can give.
Old Oct 14, 2003 | 04:11 PM
delux247's Avatar
Default Re: engine build-up ?'s (1_bad_EF)
thanks for the advice and tom did polish my comb. chambers
any more advice
dc800
Feb 3, 2004 01:38 AM
dc800
Feb 1, 2004 11:11 AM
b16supertuner
10
Jan 14, 2004 02:18 PM
slowcivic
Sep 23, 2001 06:58 PM
