How much for a rebuilt tranny and do you think I need it?
Hello fellows,
My brother will give his car to me this November when I get my license and his MaD 3 GeAr aint working. It scratches pretty bad when you shift into 3rd. He has a Gs-r tranny with a B18c5 in a Ek. Should I rebuild the whole tranny or get a Type R one with a LSD? I am only 16 and kind of confused on what to do. So any help would be appreciated.
Thanks,
Jason
Thanks,
Jason
First, I'd try a fluid change and see how it does after a couple weeks. It might "fix" it or make it more useable.
If you get a new transmission, though, I'd say get a B16 or GSR and throw in a Quaife or KAAZ LSD.
My brother added 2 1/2 bottles of redline tranny fluid couple of months ago and this just happened like a month ago. Do any of ya know the price for a Type R tranny? I think I will bring it to Jotech in Garland, Tx and let them do it. I heards its around 1k - 1.5k $$.
Thanks,
Jason
Thanks,
Jason
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XViEtBoiX »</TD></TR><TR><TD CLASS="quote">I did a search and no results on flushing tranny fluids. Can someone explain to me? I dont want to F%#^ up the transmission any worse. Thanks</TD></TR></TABLE>
sounds like you're not mechanically incline I suggust you take it to a shop to get it done. that's the best way for YOU to not **** up you tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOONCIVIC_97 »</TD></TR><TR><TD CLASS="quote">Go type-r!</TD></TR></TABLE> i agree suits the r motor that you have very well. dont bother rebulid just ride until you have enough funds and then go for the r tranny which is quite hard to come by.
be careful. if i was 16 and had that motor, i would have wrapped it around a pole.
but yea, go type r if you can afford it
Lets make this problem more easy on you. Since you got a Type-R motor with no Type-R tranny in the first-place, now's the time to get a Type-R. Hey, you got a car for free with the motor that has a busted up tranny. Just start saving, Type-R trannys run from $1,800-$2,300. Just search.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XViEtBoiX »</TD></TR><TR><TD CLASS="quote">hmmm...is flushing that hard?? I thought you just change the old tranny fluid and put in the new one. </TD></TR></TABLE>
It's easy. Remove the drain bolt with a 3/8 socket wrench and let drain. Put drain bolt back on, remove fill bolt or speed sensor and fill it up with Honda MTF. There's a picture floating around somewhere, or you can go get the Haynes manual for an Integra from your local library.
aciegoh22
Mar 17, 2009 01:24 AM
