-a/f ratio gauge help-
Old Oct 13, 2003 | 05:45 PM
0 0 0's Avatar
Default -a/f ratio gauge help-
i have a 92 civic and was wondering if someone could tell me what color wire on the ecu im supposed to tap into for the violet wire on the gauge?
Old Oct 16, 2003 | 11:30 AM
0 0 0's Avatar
Default Re: -a/f ratio gauge help- (vxHATCHATTACK)
anyone know what the color of the wire is?
Old Oct 16, 2003 | 11:58 AM
976's Avatar
976
New User
White wire under ECU pin D14, it might have a green strip on it. So, on the D ECU pin out, the largest section, from left to right on the top row count over 7, that should be the one! Good luck.
Old Oct 16, 2003 | 12:15 PM
wilsel's Avatar
Default Re: -a/f ratio gauge help- (976)
You can tap it into the same wire at the O2 sensor. Little easier only 4 wires, and only 1 is white.
chrisfromsrq
Jul 30, 2009 09:47 AM
92prelude23
Nov 17, 2008 02:09 PM
bumpin_bass
May 11, 2003 07:35 PM
LudeyKrus
Apr 6, 2003 05:24 PM
