T1R N1 Exhaust (Silencer)
Old Oct 13, 2003 | 05:07 PM
JDM_EK3's Avatar
Default T1R N1 Exhaust (Silencer)
Ok I purchase a T1R N1 Axel Back Exhaust about 3 months ago, and it came with the silencer already installed. However I personally think it looks horrible, and want it out ASAP. However after removing the alen key bolt, and using 2 pairs of pliers to reef on the silencer, it didn't even budge a tiny bit! Does anyone have any tips, or suggestions on how to remove a stubborn silencer?
Old Oct 13, 2003 | 05:59 PM
Briman2021's Avatar
Default Re: T1R N1 Exhaust (2NR)
wd-40 or some other penetrating ludricant, also, try getting the exhaust warm, and maybe a few gentle taps wiht a rubber mallet could help.
Just be careful so you dont dent your muffler or wreck your silencer in case you wanna put it back in when you figure out your exhaust is too loud or you get pulled over.
Old Oct 13, 2003 | 10:10 PM
JDM_EK3's Avatar
Default Re: T1R N1 Exhaust (Briman2021)
Ok so spray some WD-40 in there, gently tap it with a rubber malet, making sure not to knock it inside the exhaust, and the reef on it with some pliers? I've had the exhaust hot, and reefed on it with 2 pairs of pliars but it didn't even budge.
Old Jan 16, 2004 | 12:17 PM
SpoonEK2's Avatar
My silencer's been stuck for almost 12 months. I don't think it will ever come out.
Old Jan 16, 2004 | 12:20 PM
ki3t's Avatar
This user can set his title.
Default Re: T1R N1 Exhaust (SpoonEK2)
WD-40 and some strong pliers and pull the biotch out if you can.
Old Feb 16, 2004 | 10:05 AM
Team 4's Avatar
Default Re: T1R N1 Exhaust (Ki3t)
I ran my T1R with the silencer in it for 25 minutes, and it pulled richt out. Maybe try (can't remember the exact name) that tool that extends 3 prongs, and pull it out with that.
Old Feb 16, 2004 | 11:59 AM
civic_tuned's Avatar
i used a hammer on that b@#tch when its hot hit at angle the silencer will go in slanted in then add some w40 and pull it out w/ tha pliars. Its gonna be hard but be patient it will come out. good luck!
Old May 6, 2005 | 11:26 PM
TheGSRGuy's Avatar
Default Re: T1R N1 Exhaust (civic_type_r)
I took the screw out of mine, and just did a few WOT runs. I blew it out the exhaust tip eventually (fortunately no one was behind me).
Old May 6, 2005 | 11:52 PM
_Cyclone_'s Avatar
I used a slide hammer and an expandable hook (for mounting things to the drywall ceiling) to get mine out. Worked like a charm.
Zack Shea
May 8, 2016 09:21 AM
skew
Aug 30, 2009 07:51 PM
EriK20
Jun 5, 2003 04:27 PM
Scooby
Jan 8, 2002 08:38 PM
N1Spec
Oct 19, 2001 05:43 PM
