Eagle Intake Manifold for our H22 motors
Old Oct 13, 2003 | 04:10 PM
2kflamedlude's Avatar
Default Eagle Intake Manifold for our H22 motors
I was at my local shop the other day and they Showed me the Eagle Intake manifold and they would sell me that for 600 bucks.. I think thats spendy does anyone know about these?
Old Oct 13, 2003 | 04:49 PM
SsTiNgEr77's Avatar
its great if your FI
heard it only gains on the very high end if your NA...
thats all i can tell u
Old Oct 13, 2003 | 05:23 PM
Default Re: (SsTiNgEr77)
I am all NA... So maybe its a waste huh.. Even with N20
Old Oct 13, 2003 | 05:32 PM
satan_srv's Avatar
Default Re: (2kflamedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kflamedlude &raquo;</TD></TR><TR><TD CLASS="quote">I am all NA... So maybe its a waste huh.. Even with N20</TD></TR></TABLE>
I don't think it would be worthwhile for the amount of times you spray.
I may do it on my lude though..I'm interested to see if I can make big gains.
Old Oct 13, 2003 | 05:41 PM
SKDRCR's Avatar
Default Re: (satan_srv)
anybody have dyno's before and after?
this goes 4 the turbo guys
Old Oct 13, 2003 | 05:53 PM
xxmaxhardcorexx's Avatar
Default Re: (SKDRCR)
make sure it has a IAV , air temp sensor and a throddle bracket...
i'm not sure if the golden eagle comes with the hook up or not
ask before you buy.
Old Oct 13, 2003 | 05:59 PM
PrecisionH23a's Avatar
Default Re: (KeithTurbo)
With most of the drag manifolds you have to tap and thread the manifold for vacuum sources as well as some sensors. Maybe GE has done this for us though...
The manifolds benifit on top end but you compensate this gain by losing some low end power. As for n/a, it is definetely not worth it for street driving unless you are running a fully built high compression motor. A buddy of mine with a neon does have a custom sheetmetal intake manifold and he told me he picked up some nice top end on the dyno.
Old Oct 13, 2003 | 06:01 PM
your gonna give it a try?
Old Oct 13, 2003 | 07:01 PM
i have a venom intake manifold. Bruce from venom ( the guy with drag civic)
did a cudtom IAV, and a air temp sensor so that worked out but i'm running a GSR
throddle body set up for the cable.. i got to tell ya if i didnt live in socal i could not of had my manifold done... if i orderded it and it came the way it did i would had
sent it back..... any whoo i dont have any HP gains on it yet but if your planning
installing this on a stock motor you will be sorry you did.. hehe is a picture
of it on my car
Old Oct 13, 2003 | 07:34 PM
NXLude's Avatar
2k....arent you running 11.5 cr forged pistons and big cams? if so it may help....did you ever dyno it? what shop has it?
Old Oct 13, 2003 | 08:33 PM
Keith, nice looking set-up.
What did you do for the plug going to the EGR valve so you do not throw a code?
Old Oct 13, 2003 | 08:45 PM
Default Re: (GudeH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">Keith, nice looking set-up.
What did you do for the plug going to the EGR valve so you do not throw a code?</TD></TR></TABLE>
Thanks.. there is a plug on the manifold but i blocked it off. i'm running a p28 hondata ecu. so i no longer need it
Old Oct 13, 2003 | 08:58 PM
Do you know if I can take it off of a p74 hondata ecu without throwing a code?
Old Oct 13, 2003 | 09:14 PM
i'm not sharp on p74's?? what are you using for ECU hondata or aem ect...
you can do a lot of **** with a p28 and they are cheep... actually the reason i bought a p28 was for the manifold, so we will see what happens...but ....um
your 400+ hp man whats your goal for hp? anyways
from what i heard this manifold dosent make any power untill around 5,800 rpm's
on the h series...by the way i take it you are running race gas for 20 psi??
Old Oct 13, 2003 | 09:24 PM
Hondata 4b with the LS p74 ecu. The reason I have to run the LS ecu is since my motor is non v-tack.
My goal for power has been met as of right now. The motor is capable of another easy 30-50 with the current set-up but we were running out of time with the dyno and the elbow on the compressor kept popping off.
For 20psi we tuned it with 103 octane... Originally I planned on running c16 though with 25psi. Next trip to the dyno next summer I will be looking for 500 to the wheels. Then it is time to invest in a Supra.
Sorry to get off topic.
Old Oct 14, 2003 | 09:57 AM
Default Re: (NXLude)
Yeah.. I do.. No Dyno yet.. I am having fastlane tune it for me.. My car been down for a year.. Trying to finish the paint job and what not.
Old Oct 14, 2003 | 01:05 PM
TurboSam's Avatar
the Golden Eagle manifold is agreat street upgrade
i have one on my car, it has 5 actual vaccuum nipples, and 2 1/2" NPT threaded port for other sources, but if you are running additional vacuum using items, the GE vacuu mani is a great upgrade too
the GE intake though was so easy to install, and UNLIKE other sheetmetal intake manifold, the IACV bolts right up to this manifold without ANY modification, i HIGHLY recomend GE's products
Old Oct 14, 2003 | 01:16 PM
Shakes's Avatar
space cadet
Default Re: (Turbo Sam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Sam &raquo;</TD></TR><TR><TD CLASS="quote"> i HIGHLY recomend GE's products</TD></TR></TABLE>
uuuhhhh..... Sam.... you got some white **** hangin on your chin dude.
Old Oct 14, 2003 | 07:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">Hondata 4b with the LS p74 ecu. The reason I have to run the LS ecu is since my motor is non v-tack.
Sorry to get off topic.</TD></TR></TABLE>
well for a peice of mind if you wanted to get into a custom manifold i would run the p28 because it dosent have a egr. who cares if you dont have v-tack anyways
it would just not be used in the hondata set up..
500 to the wheels on a street car is ******* crazy!!! good luck
and i know what your saing about that supra bit... i'm already looking around
for a rx7.. hondas are fun but i want somthing with ***** from the factory..
i dont think i will ever go as far as i did my next car as i did with this one.
but a change would be nice
hduceducesol
Apr 17, 2007 02:30 PM
Forrest Gump 9
Oct 3, 2006 01:17 PM
kamAccord
May 20, 2005 05:30 PM
Garcia-Racing
Apr 3, 2004 03:51 PM
