Need some pointers for time shaving.
Old Oct 13, 2003 | 03:53 PM
TrickHonda98's Avatar
Default Need some pointers for time shaving.
well, today i went to my local 1/4 track and did 4 runs, the best time i got was 13.88@ 102.1MPH and was wondering if i could get any pointers on shaving the .8 seconds off of there and try tpo get into the 12's. I ran track slicks and a test pipe when i did it, and on the fourth try I managed to lunch hard. I shifted at least 500 Rpms after each redline on each gear. next time, i'll remove my backseats and run open intake. but i know theres got to be some other things that can shave some time off my 13.88, so then i can go back down there and own that one dude and his old firebird and show what imports are all about.
Thanks in advance!
Old Oct 13, 2003 | 04:01 PM
Default Re: Need some pointers for time shaving. (TrickHonda77)
bump, anyone? help is appreaciated!
Old Oct 13, 2003 | 04:05 PM
1999all_motoR_teg's Avatar
Why the hell would you shift 500rpm's AFTER your redline?? There's no point in shifting after the redline unless your making power that high. You are probably losing time as you lose power when you rev it out past the redline.
Open intake?? Do you mean open header???
Old Oct 13, 2003 | 04:07 PM
Andres-eh2's Avatar
knowing your mods would also help?
B18C5 block/B16 head, stock?
Old Oct 13, 2003 | 04:08 PM
EGinNY's Avatar
Default Re: Need some pointers for time shaving. (CIVIC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CIVIC2 &raquo;</TD></TR><TR><TD CLASS="quote">
Open intake?? Do you mean open header???</TD></TR></TABLE>
i think he meant open intake, as in no filter(dont know if theres a big difference but seen it b4)
Old Oct 13, 2003 | 04:11 PM
HXvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CIVIC2 &raquo;</TD></TR><TR><TD CLASS="quote">Why the hell would you shift 500rpm's AFTER your redline?? There's no point in shifting after the redline unless your making power that high. You are probably losing time as you lose power when you rev it out past the redline.
he's right. there no power after the redline. start with your back seat and take out all the **** in your trunk. what r your mods??
Old Oct 13, 2003 | 04:27 PM
Default Re: Need some pointers for time shaving. (HXvtec)
thanks, now I know that one guy i was talking to didn't know ****, he said a few revs ober will bring up speed.
and open intake, no filter, but i have a turbo that runs 3-5lbs boost, the head has upgrads, cams/shaft, valves
the block has many things complete change in all parts, it's practically a new block straight from Japan. and thats what i forgot, the spare tire, and aal that ****.
how about some more reccomendations, thanks guys, you are helping, from now on, i won't talk tech to some *** at the chat room in aol auto. THANKS guys
Old Oct 13, 2003 | 04:32 PM
anyone else? i need help here. thanks in advance!
Old Oct 13, 2003 | 04:38 PM
nsxmatt's Avatar
Need to know your whole setup and car. In your sig you said c5 block and head but now you say turbo at 4lbs??? I'd say turn up the boost to at least 7 to take advantage of the turbo being on the car in the 1st place.
Old Oct 13, 2003 | 04:39 PM
Miracle_X_Bar's Avatar
Default Re: Need some pointers for time shaving. (nsxmatt)
NEVER TAKE YOUR FOOT OFF THE GAS!!! POWER SHIFT!!!
Old Oct 13, 2003 | 04:51 PM
MilanoRex's Avatar
Default Re: Need some pointers for time shaving. (Miracle_X_Bar)
SHAVE some time off your quarter mile with a Mach 3 Turbo
Old Oct 13, 2003 | 04:52 PM
Pete_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miracle_X_Bar &raquo;</TD></TR><TR><TD CLASS="quote">NEVER TAKE YOUR FOOT OFF THE GAS!!! POWER SHIFT!!!</TD></TR></TABLE>
That should work
HXvtec's Avatar
and make sure u have a spare clutch
Old Oct 13, 2003 | 04:55 PM
Ricey McRicerton's Avatar
Yes if you hate your cluch this is a good idea.
Old Oct 13, 2003 | 04:57 PM
aira
Guest
Posts: n/a
Default Re: Need some pointers for time shaving. (Pete_SI)
I think the only reason he goes a little over redline is so he can stay in the powerband.
Old Oct 13, 2003 | 05:00 PM
h22John's Avatar
its been proven time and again that powershifting is almost pointless, not completely but almost, unless of course ur into breaking stuff. and btw .8 seconds is alot of time to shave off when ur already goin 13.8.
Old Oct 13, 2003 | 05:06 PM
JV's Avatar
JV
Who?
Weight reduction, open header/downpipe, remove rear bumper cover. That should get you pretty close with a good launch.
Old Oct 13, 2003 | 05:13 PM
hybridzOr's Avatar
Default Re: Need some pointers for time shaving. (MilanoRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MilanoRex &raquo;</TD></TR><TR><TD CLASS="quote">
muhahahaha can you beleive they have a quatro now......
hybrid: who remembers watching something making fun of these blades by having more and more blades for "the close shave" lol
Old Oct 13, 2003 | 05:18 PM
buda18's Avatar
Default Re: Need some pointers for time shaving. (HybridRacer)
hahaahahha
yes Hybrid i believe that was SNL when they had like 20 blades and they shaved the guys face and they showed it all squirting out blood after one swipe...it was great
Old Oct 13, 2003 | 05:20 PM
Function's Avatar
i would work on running more boost because thats pretty low
Old Oct 13, 2003 | 05:22 PM
hybridzOr's Avatar
Default Re: Need some pointers for time shaving. (buda18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buda18 &raquo;</TD></TR><TR><TD CLASS="quote">hahaahahha
yes Hybrid i believe that was SNL when they had like 20 blades and they shaved the guys face and they showed it all squirting out blood after one swipe...it was great</TD></TR></TABLE>
yep...thats the show....lmao...
Ot: I hope you shave your time..
Old Oct 13, 2003 | 05:26 PM
RS_91's Avatar
so you have:
C5 block
b16 head
cams/valves upgrade
turbo with 5lbs of boost
and Intake, header, exhaust (I assume)
I dont know but seems to me like you should be running better than a 13.8
Could be your driving, but I think you can definently improve that time.
Old Oct 13, 2003 | 05:40 PM
Default Re: Need some pointers for time shaving. (h22John)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22John &raquo;</TD></TR><TR><TD CLASS="quote">its been proven time and again that powershifting is almost pointless, not completely but almost, unless of course ur into breaking stuff. and btw .8 seconds is alot of time to shave off when ur already goin 13.8.</TD></TR></TABLE>
well whoever proved it didn't know what they were doing!! i've proven myself that it works.......
Old Oct 13, 2003 | 05:45 PM
b18bcivic's Avatar
go on a diet
Old Oct 13, 2003 | 05:50 PM
hey guys, thanks for the pointers, you've been some good help. my turbo can only go up to5.5 lbs of boost but i do plan to upgrade that. thanks alot. I'll do every single one of these rcommendations, luckily for me, I have a spare ACT clutch on hand and my freind does'nt want his anymore. Thanks! keep the tips coming!
p.s., the Mach 3 turbo thing was funny, LOL, i saw that too, I wonder if they'll do another one, use 50 blades next time.
