WELL SHIT!!!(wheel studs again)
i took some of my lugnuts off. 2 straight off, one broke and the last one is completely fucked up. When i turn it, it just spins around without loosening. Anyone know how to fix this?PLEASE HELP!!
U need to replace the lugnut studs.
Go buy some lug nut studs from honda dealership. should be around 3-5 bucks each.
if u'r trying to do this by yourself u need a 32'' with impact. and then just take off all the stuff that are in your way, and replace.
walla ~
walla ~
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">Is that with using hand tools?
How about a impact gun?</TD></TR></TABLE>wouldnt an impact gun just make it move really fast in circles?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all stock »</TD></TR><TR><TD CLASS="quote">take it to a machine shop, they can probably cut it off? </TD></TR></TABLE>how am i gonna take it there if the wheel is still stuck on there?...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greebler »</TD></TR><TR><TD CLASS="quote">discount tire can take care of that cheap.</TD></TR></TABLE>
hrmm...the front wheel is on by one lug that is partially on...i dont think i wanna drive it anywhere
what kind on wheel is it?
If they are black outs or somthing like it just use a hammer to brake the stud. thats what I did but I was rolling on stock 13's.
When it happened at the track on my slick one of my friends bent the stud just enough to bind it in the hub and the lug came right off.
go buy a dremel tool and cut it yourself then go buy the studs, then return the dremel for a full refund...<<< ghetto version. works for me.
this happened to a car i was working on one time. luckily i had an impact wrench and i just kept impacting it and it eventually came off. basically, all that turning melted the stud off and i could see half of it still stuck onto the lug nut.
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonas »</TD></TR><TR><TD CLASS="quote">this happened to a car i was working on one time. luckily i had an impact wrench and i just kept impacting it and it eventually came off. basically, all that turning melted the stud off and i could see half of it still stuck onto the lug nut.
good luck</TD></TR></TABLE>
hrmmm that was what i wanted to do but.....i dont have real power tools...and is it hard to replace studs
I suggested an impact, since I don't know how freely its spinning. If you are using a hand tool, and it spins, but still takes some effort to turn, an impact can loosen the nut still with the stud spinning. But there needs to be some resistance on the stud side.
If its spinning freely....you'll have to cut.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerx707 »</TD></TR><TR><TD CLASS="quote">if the wheel stud just spins then you need to get a whole new hub because the grooves aren't there anymore. If you have an open lugnut then you can drill into the stud. I did this on mine and it eventually came off.</TD></TR></TABLE>
damnit...im gonna drill that **** tomorrow.
like the other guy said... if there is still decent resistence then you should be able to get it off with an impact gun. if it spins totaly freely be prepared to have the worst day of your life when you go to cut it off.
if it were in my shop and it spun totaly freely, i would tack weld the back of the stud to the hub then use an impact gun.
BTW an impact gun is much different than doing it by hand... the impact gun hits it several times per second, not just turning it... it hits it hard in very fast pulses so you have a good chance of getting it off with an impact.
timmy0tool
10
Dec 19, 2007 03:25 PM
RexNDex
Mar 26, 2004 07:41 AM
