Brake Master Cylinder Upgrade
Old Oct 13, 2003 | 03:03 PM
ares650's Avatar
Default Brake Master Cylinder Upgrade
I have a 95 Civic SI with ABS. The ABS pump took a **** and the Master Cylinder also needed replacement. I decided to rip the ABS out and all the line and sensor (I saved 27lb.).Keeping my four wheel disc brakes, I will be replacing the brake lines with brake line out of a cx to bypass the ABS pump. What should I do with the Brake Booster, Brake Master Cylinder, Proportion Value? I have hard about a 1inch Master Cylinder, what car does it come in?
Old Oct 13, 2003 | 03:38 PM
Bnjmn's Avatar
Default Re: Brake Master Cylinder Upgrade (ares650)
You can go with a 1" MC/Booster from a 94+ GS(R). Get any double (inverted) flare lines/unions from Advance Auto.
Or you can get a 15/16" MC/Booster from a 94+ RS (non-ABS).
Grab the prop valve from the RS. I think there are some other cars with the 40/40 prop valve, but I don't know which ones.
Ben
Old Oct 13, 2003 | 03:40 PM
poison's Avatar
You can keep the ABS and upgrade the master cylinder/booster if you'd like. I also have a working GSR m/c 15/16ths available.
Or you can convert to non-abs by removing them, and get an RS M/C if you would like to upgrade.
Old Oct 13, 2003 | 05:43 PM
phantom_sol's Avatar
Default Re: Brake Master Cylinder Upgrade (poison)
1" master cylinder came on 98+ gsr and type r's. they are abs i believe. the largest non abs master cylinder is 15/16
for any integra brake master cylinder you also need to replace the brake booster. brake boosters arent abs specific, its everything from the mastercylinder down. proportion valves, any non-abs car with 4 wheel disk will work.
https://honda-tech.com/zerothread?id=152884
https://honda-tech.com/zerothread?id=641845
https://honda-tech.com/zerothread?id=641446
Old Oct 13, 2003 | 05:47 PM
snapcase318's Avatar
Maybe something like this?
https://honda-tech.com/zerothread?id=364783
Old Oct 15, 2003 | 06:09 PM
ares650's Avatar
Thanks for the input!!!!
What year civic has 4wheel disk break with no ABS?
Old Oct 15, 2003 | 06:45 PM
Default Re: (ares650)
del sol si/vtec
92-95 civic si hatch
94+ integra rs (or other non abs integra of that year)
um...anyone else?
Old Oct 15, 2003 | 07:25 PM
NonovUrbizniz's Avatar
Loved
Default Re: (phantom_sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phantom_sol &raquo;</TD></TR><TR><TD CLASS="quote">del sol si/vtec
um...anyone else?</TD></TR></TABLE>
90-93 teg non abs master/boosters work too... direct bolt in... No re-bending or moving lines to fit... The prop valve doesn't bolt up but it's easy enough to mount it to a bracket and the bracket to the stock location.
Old Oct 15, 2003 | 08:00 PM
Default Re: (NonovUrbizniz)
do you have to rebend lines to fit for 94+ master cylinder? i thought (or more so heard) it was teh same fittings. thena gain. the 90-93 mastercylinder will bolt up to the STOCK booster just fine, and those are 15/16 as well
Old Oct 15, 2003 | 08:33 PM
ares650's Avatar
95 SI hatch is ABS....that is what I have
Old Oct 16, 2003 | 07:39 AM
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phantom_sol &raquo;</TD></TR><TR><TD CLASS="quote">do you have to rebend lines to fit for 94+ master cylinder? i thought (or more so heard) it was teh same fittings. thena gain. the 90-93 mastercylinder will bolt up to the STOCK booster just fine, and those are 15/16 as well</TD></TR></TABLE>
I believe all 90-00 non-abs 15/16ths master/boosters will bolt straight up... No bending...
The 1" requires bending...
The 15/16ths master WILL NOT bolt up to the stock civic booster... it would if it could go in upsidedown (at least mine was that way)...
For ANY of the swaps you need both the master and booster I believe...
Old Oct 16, 2003 | 07:45 AM
piscorpio's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">
For ANY of the swaps you need both the master and booster I believe...</TD></TR></TABLE>
b18c5-eh2's write up about the 91 ex MC, says it does not require a booster swap. Someone posted a link in this thread in an earlier reply.
globlctzn's Avatar
A 15/16ths M/C from a 1991 civic ex sedan will bolt up to the stock civic booster and the lines. I know because I have one bolted to my stock 5th gen cx booster right now.
Old Oct 16, 2003 | 07:52 AM
Kalokohan's Avatar
New User
Default Re: (globlctzn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by globlctzn &raquo;</TD></TR><TR><TD CLASS="quote">
A 15/16ths M/C from a 1991 civic ex sedan will bolt up to the stock civic booster and the lines. I know because I have one bolted to my stock 5th gen cx booster right now. </TD></TR></TABLE>
I know he's right because I have one too.
Old Oct 16, 2003 | 08:03 AM
Default Re: (Kalokohan)
ok.... early integra and civic 15/16 will bolt up. but any 94+ integra bc will require a booster swap as well
Old Oct 16, 2003 | 08:13 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
91 Civic EX master here.
Don't get rid of ABS. The minor weight savings pale in comaprison to the life savings.
Old Oct 16, 2003 | 08:35 AM
DaX's Avatar
DaX
Loved
Community Favorite
Anyone got anything to say about an OEM master cylinder vs. an Auto-Zone replacement master cylinder? If they're pretty much the same in quality, I'll go with the AZ MC, because it's cheaper.
Old Oct 16, 2003 | 08:43 AM
globlctzn's Avatar
Default Re: (DaX)
I used a beck and arnley one, which is available at AZ. Its a rebuild nissin so its OEM quality.
Old Oct 16, 2003 | 09:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kalokohan &raquo;</TD></TR><TR><TD CLASS="quote">
I know he's right because I have one too.</TD></TR></TABLE>
Kalokohan, how's the difference in stock vs. the EX one? Is it a worthwhile upgrade?
Old Oct 16, 2003 | 10:59 AM
BROOD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ares650 &raquo;</TD></TR><TR><TD CLASS="quote">95 SI hatch is ABS....that is what I have </TD></TR></TABLE>
Not all 1995 Si hatches have ABS
Old Oct 16, 2003 | 11:15 AM
madman604's Avatar
Default Re: Brake Master Cylinder Upgrade (snapcase318)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snapcase318 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe something like this?
https://honda-tech.com/zerothread?id=364783 </TD></TR></TABLE>
good reading.
Old Oct 16, 2003 | 11:41 AM
Kalokohan's Avatar
New User
Default Re: (snapcase318)
Kalokohan, how's the difference in stock vs. the EX one? Is it a worthwhile upgrade?</TD></TR></TABLE>
Well it's not like I just replaced the MC, I replaced the MC because I got an 11" brake upgrade from Fastbrakes, using 11" brembo rotors, GSR calipers and Hawk Pads. When I first did the brake upgrade and left the stock MC, my pedal would almost hit the ground during hard braking. After the 91 civic EX MC install, my pedal feel is better than ever, i don't have to apply as much pressure on the pedal to get full braking power.
Not the best pic to show brakes but here is the 11" Brake Upgrade from Fastbrakes...the caliper is so close to the wheel, I can barely squeeze a penny in between.
Modified by Kalokohan at 3:53 PM 10/16/2003
Old Oct 16, 2003 | 12:00 PM
elwood's Avatar
Default Re: Brake Master Cylinder Upgrade (Turbo E)
I have the 1" from the CTR. The JDM Integras some times had
the 1" also.
Old Oct 21, 2003 | 04:57 AM
ares650's Avatar
Default Re: Brake Master Cylinder Upgrade (elwood)
Who or where can I get the 1" MC, and for how much? What is the biggest brake setup that I can stuff under a 15" rim? or 16"? The brake shouldn't hit my 13" Bogerts right?
Thanks for all the help guys!!!!!!
Old Oct 21, 2003 | 05:32 AM
ki3t's Avatar
This user can set his title.
Sorry for the jack but, since this subject is on upgradeing BB and MC's.. I got a quickie question. I did a 5 lug conversion on my 93 EX coupe. Is it ok if I use an LS - BB & MC with the 95 Civic EX ABS portioning valve? Thats what I was told to use.
