difference in log style and full legth tube turbo manifolds
Old Oct 13, 2003 | 02:52 PM
92lSilude's Avatar
Default difference in log style and full legth tube turbo manifolds
Ive noticed the Full length tube turbo manifolds are anywhere from 800-1500$ while the log styles are from 300-500... Whats the big difference... spool time... horsepower... what is it?
Old Oct 13, 2003 | 02:59 PM
R6Elmo's Avatar
Default Re: difference in log style and full legth tube turbo manifolds (92lSilude)
tubular manifolds are better in directing the air. Its similar to how there are some good headers and bad headers. The length, dimeter etc of the piping matter in the end. There are equal length tubular manifolds, and then there are your manifodls that equalize tubes 1 and 4, and then 2 and 3.
And yes, it does yeild more horsepower/torque, spool etc.
Old Oct 13, 2003 | 03:02 PM
92lSilude's Avatar
Default Re: difference in log style and full legth tube turbo manifolds (R6Elmo)
ok, i can understand that... well heres what im looking at.... and is the horsepower torque output 400$ worth better then the logstyle(what kinda numbers at say 8psi on a H23 if you can please)? thanx for the help
http://www.lovefab.com/manifolds/sidewinder.html
Old Oct 13, 2003 | 03:03 PM
Jared's Avatar
At 8psi, I seriously doubt you'll notice a difference.
Old Oct 13, 2003 | 03:07 PM
92lSilude's Avatar
Default Re: difference in log style and full legth tube turbo manifolds (Jared)
well assuming i would do a buildup and run say 14-16psi later on with a T3T4 57trim (decent flow i guess) would it be worth it to go ahead and buy it with my original 8psi setup? i meen, its got a lifetime warrenty which kicks major *** so i wont have to worry about it lasting
Old Oct 13, 2003 | 03:16 PM
Tinker219's Avatar
Since I sold my SST a week ago, Ive been slowly building this bad boy. I like it Even w/the longer IC piping, Im still getting 6 psi at 4100ish rpm(used to be 4500ish w/the SST).
I should be able to use this when the engine goes rear-ward, so Ill let you all know how that goes.
So in a word...if you are going to build up on your turbo setup, get a nice manifold now, because all of the rest of the setup is pretty much based on the manifold.
*Im not saying to "Buy my manifold!", Im just telling you from experience what Ive learned...
Modified by Tinker219 at 7:42 PM 10/13/2003
Old Oct 13, 2003 | 04:35 PM
DLB1994's Avatar
Default Re: difference in log style and full legth tube turbo manifolds (Tinker219)
check sig i have a brand new manfold for a h23 forsale
Old Oct 13, 2003 | 04:41 PM
CheezeFrog's Avatar
tubular manifolds look better then cast iron ones. other than that, iono...
Old Oct 13, 2003 | 04:54 PM
TurboJesse
Guest
Posts: n/a
Default Re: difference in log style and full legth tube turbo manifolds (CheezeFrog)
you can make more than enough power with either type...the rest is up to you to decide if the difference in $ is warranted
Old Oct 13, 2003 | 05:05 PM
92lSilude's Avatar
Yeah, thanx everyone, i think il end up going with the long tube... Hey tinker... is that a sidewinder... thats what i was lookin at, ill get to keep my AC ... i just cant imagine the log style flowing as goog as a long tube... plus with the turbo a lil further from the block, temps might be a touch cooler... and with long tube, the heat will dissipate throughout a lil better instead of concentrated on 1 log... nothing big like 10-15degrees, but every lil bit helps. If anyone else has an opinion id love to hear it
R6Elmo's Avatar
Default Re: difference in log style and full legth tube turbo manifolds (Mpir3)
It would be easier to make more power with an tubular length manifold. Yet the log style manifolds can yeild huge power numbers. 450hp+ with no issues.
Old Oct 13, 2003 | 05:14 PM
Tinker219's Avatar
Actually, the tubular manifolds put out ALOT more heat then the log manifolds. A vented hood wouldnt be a bad idea to help dissipate some of the heat...
Old Oct 13, 2003 | 05:55 PM
92lSilude's Avatar
well, im still lookin at the sidewinder becasue it looks like a great manifold but, what kind of power gains are involved at the same medium Psi (8-14) between a longtube VS a log style... and spool up time as well? please and are there any log style that keep Ac? does anyone have expereince with both who can give me there opinoin
Old Oct 13, 2003 | 06:04 PM
Charlie Moua's Avatar
what would be a good rule of thumb to use when decideing if you would benifit with a upgrade of turblar
same BOOST and setup just retuned. upgrading and spending $400+ on a nice tube mainfold would be well worth it if the gains were reasonable, but some comsumers might be dissapointed if they only have a 220-250whp setup and spent extra money on a NEW manifold only to find out they they got better spool but only gained like 5whp and 5tq.
as the WHP goes up , I'm sure the gains will be more worthwile.
wolfman93
Nov 16, 2015 06:10 PM
1FastCoupe
Jun 15, 2006 09:42 AM
96 EX
Jan 18, 2006 10:08 AM
mookhaasa
Aug 26, 2005 11:42 AM
turtle-eg
Nov 13, 2004 03:36 AM
