Ek seats in EGs?? did a search but ....
Actually I want to know if Acura EL seats fit in an EG, but seeing as you dont have the EL in the states, i imagine the seat construction bolts up the same as an EK sedan or coupe or probably hatch.
Thanx for any help guys
ek seats fit in eg's with a little modification.
(you have to use the eg mounts to the ek sliders, and have to cut one bolt off the ek sliders)
the problem is, ek seats sit about an inch to two inches higher than eg seats. I have 2k SI seats in my coupe, and i hit my head every once in a while getting out. - and i'm short, 5'5"
3 bolts match up with swaping seats from these separate generations the tab closest to the ebrake side on both passenger and driver is too short I think ...or was it too long
[QUOTE=AmginE]ek seats fit in eg's with a little modification.
that's why you use the eg mounts, so all 4 bolts line up and it's secure to the car. i still have pictures of the sliders (ek vs eg) and mounts, i'll have to find them.
