Tried searching: D15z1...what exactly does it/does it not share with D15b?
I want to do a turbo D series.
I noticed I've got a d15z1 currently.
I know I'll need to swap transmissions, but other than that, what exactly seperates the z1 from the likes of a vtec d15b? Is it more than just a vtec head? Are there differences inside the block?
I'm trying to figure out if it's possible for me to do a mini-me or whatever on my current block and then turbo, or if I should just save up and fork over for a JDM 15b, or a Z6?
I've tried searching, but I haven't found anything that I'm particularly looking for.
TIA.
TIA.
well you should remember that with the minime, your compression will raise.
and it wont be as easy to run a turbo setup on a high comp engine.
you want that low comp so you can run more boost.
the rods and pistons are different. The z1 has dished pistons, which with a mini-me setup will actually create a low CR, somewhere in the neighborhood of 7.5:1. The rods in the z1 are similar to the z6 in length (if not identical, can't remember right now). As far as the actual block, I am almost certain they (d15 blocks) are all identical, its just the stuff inside that differs. Check my sig. under the d series piston comparo, there is good detailed info there. Hope this helps.
Rods are the same between the D15Z1 and D15B. The main differences is the pistons and the VTEC vs. VTEC-E head.
Both D15Vtec motors use 137 mm long rods, but they are not as string as normal D16 rods.
That answers a lot of the questions I had, guys. Thanks.
Does anybody know what the HP limit is of the stock D series bottom end? I guess stock for stock the z6 would be the stouter since Mista Bone says the rods are stronger?
Are there any manufacturers of forged internals for any of the D series?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_EH »</TD></TR><TR><TD CLASS="quote">
Are there any manufacturers of forged internals for any of the D series?</TD></TR></TABLE>
Yes, there are actually a few. Eagle, Crower, CP pistons, SRP, JE, AEBS, among others, all have d16 applications.
2JZGod
Sep 13, 2016 05:47 AM
