Question about rattling sound after I installed the Apex N1...
Old Aug 30, 2001 | 09:01 PM
AllMotorITR's Avatar
New User
Default Question about rattling sound after I installed the Apex N1...
I had my Apex N1 Catback/JDM Header/AEM CAI installed like 2 days ago, and when I am at idle there is a loud rattling sound as if something is touches causing something to rattle against eachother.. ANyone had this problem and know what to do?
Old Aug 30, 2001 | 09:04 PM
Chris's Avatar
Default Re: Question about rattling sound after I installed the Apex N1... (PYTypeR408)
Is it near the CAT, or Resonator? Sounds like it might be a heat shield, if they werent already removed.
Old Aug 30, 2001 | 09:06 PM
Bob#455's Avatar
Default Re: Question about rattling sound after I installed the Apex N1... (Chris)
Like Chris said, it's most likely the heat shields above the cat and/or b-pipe.
Old Aug 30, 2001 | 09:07 PM
New User
Default Re: Question about rattling sound after I installed the Apex N1... (Bob#497)
Upper and Lower heatshields were removed, they dont fit on the JDM header.
Old Aug 30, 2001 | 09:08 PM
Chris's Avatar
There are heat shields under the car shielding the exhaust from the under body.
Check those!!!!
Old Aug 30, 2001 | 09:09 PM
Yellow3TypeR's Avatar
if you remove the heat shield, make sure the brake lines aren't exposed. Prolly not a good idea to heat up those lines.
Old Aug 30, 2001 | 09:39 PM
EPGONZALEZ's Avatar
Default Re: Question about rattling sound after I installed the Apex N1... (Yellow3TypeR)
i had a rattle with my apex..it was coming from the rear exhasut section..the rubber hangers were worn out and causing it to have to much freedom to jump around..hope this helps..even if your car is new..while running check under the car.and try and pinpoint were the sound is coming from..that would help us out a little more..
Old Aug 30, 2001 | 10:01 PM
akachef's Avatar
New User
check to make sure your shifter isn't hitting the exhaust as well. i'm not particularly familiar with your platform, but that's a common problem with most of the cars i work on
Old Aug 30, 2001 | 11:02 PM
SpoonCivic's Avatar
New User
Default Re: Question about rattling sound after I installed the Apex N1... (akachef)
the tip on the N1 is huge..its prolly hittin ur rear bumper. thats what happens with me
Old Aug 31, 2001 | 06:56 AM
ITR-01-0977's Avatar
New User
Default Re: Question about rattling sound after I installed the Apex N1... (SpoonCivic)
I have a Spoon header, carsound cat, and Apex N1 on my R.... all of my rattles came from the heat sheilds above the s pipe on my exhaust...I just removed them and havent had a problem since.
Old Aug 31, 2001 | 07:52 AM
SpeedPak's Avatar
Default Re: Question about rattling sound after I installed the Apex N1... (ITR-01-0977)
my rattles went away once I bent away the heat sheiled over the exhaust. No rattles since.
fais
Old Aug 31, 2001 | 09:27 AM
mugenr#1011's Avatar
Default Re: Question about rattling sound after I installed the Apex N1... (SpeedPak)
try looking right where the axle back hooks up, its probably the hanger.. when i got my mugen exhaust it did the same thing. went and got the hanger bent and that was the end of that..good luck.. mugen
Old Aug 31, 2001 | 11:42 AM
AWDSOME's Avatar
Default Re: Question about rattling sound after I installed the Apex N1... (mugenr#1011)
The common place for the N1 to hit is at the connection of the A pipe (straight) to the B pipe (S shaped). The place where thise two bolt together will be extremely close to the heat shield that is there. Just take a scewdriver and bend the heat shield back a little bit. I also have a Spoon Header, high-flow cat, and Apex N1 and that is the only place that I ever had contact.
Good Luck.
SD_EM1
Oct 21, 2003 11:39 AM
PYITR821
Aug 17, 2002 01:01 PM
Wet Nudl
Feb 5, 2002 08:35 AM
MintyDip
Jul 30, 2001 10:28 AM
citanest
Jun 18, 2001 09:35 PM
