gsr and ITR flywheel specs
Old Oct 13, 2003 | 11:06 AM
DOHCon15s's Avatar
Default gsr and ITR flywheel specs
Would a gsr or ITR flywheel give me anymore power for a 95 ls. would it not be worth buying because I have a tight budget and dont feel liek wasting any money if it wont work a lot better
Old Oct 13, 2003 | 11:14 AM
P1mpSlap's Avatar
ITR
Old Oct 13, 2003 | 11:17 AM
DOHCon15s's Avatar
Default Re: (P1mpSlap)
whats the weight difference between an ls and a ITr or a gsr
Old Oct 13, 2003 | 12:37 PM
typer_801's Avatar
Default Re: gsr and ITR flywheel specs (DOHCon15s)
Don't think it's anymore than 2-3 lbs. You can go even lighther than an ITR and be perfectly fine.
Old Oct 14, 2003 | 05:51 AM
DOHCon15s's Avatar
Default Re: gsr and ITR flywheel specs (typer_801)
does anyone know a company that has a inexpensive flywheel for around 150 that is ligther than an ITR and how much does an ITR wiegh compared to a ls
Old Oct 14, 2003 | 05:53 AM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCon15s &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know a company that has a inexpensive flywheel for around 150 that is ligther than an ITR and how much does an ITR wiegh compared to a ls</TD></TR></TABLE>
there is no aftermarket company that makes flyhweels NEW for 150.
the LS flywheel weighs just as much as the GSR and the ITR flywheel is SIGNIFICANTLY less than all of those.
Old Oct 14, 2003 | 06:28 AM
DOHCon15s's Avatar
Default Re: gsr and ITR flywheel specs (P1mpSlap)
ok my last question, will a b16 flywheel fit rigth up into a ls
Old Oct 14, 2003 | 06:35 AM
whiteyg2rs's Avatar
All b-series flywheels are interchangable(excluding the early preludes). An LS or GSR flywheel is around 19-20lbs and an ITR is around the 14lb range. If you want to go lighter than that you can buy the ITR flywheel and have it lightened a little. Thats probably the cheapest route.
Old Oct 14, 2003 | 06:46 AM
DOHCon15s's Avatar
Default Re: gsr and ITR flywheel specs (whiteyg2rs)
whiteyg2rs knows whats up thanks a lot man
Old Oct 17, 2003 | 09:59 AM
HmgLauj69's Avatar
how lite can you go and still be safe with flywheels?
Old Oct 17, 2003 | 10:27 AM
IntEGNYC's Avatar
Default Re: gsr and ITR flywheel specs (HmgLauj69)
ive seen 6lbs flywheels but i imagine you have to mate that with a stage 3 clutch to grab on to that thing...
Old Oct 17, 2003 | 10:32 AM
HmgLauj69's Avatar
Default Re: gsr and ITR flywheel specs (IntEGNYC)
i heard something about going to lite is unsafe, something about balance i think? can anyone enlighten me
Old Oct 21, 2003 | 10:26 AM
DOHCon15s's Avatar
how light of a flywheel could i go on an itr clutch
Old Oct 21, 2003 | 10:28 AM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCon15s &raquo;</TD></TR><TR><TD CLASS="quote">how light of a flywheel could i go on an itr clutch</TD></TR></TABLE>
the flywheel weight and what kind of clutch you use really dont have to do with another.
Flywheel weight will affect the crank shaft rotation than the engagement of the clutch. IMO the lighter the better. If Comptech still makes their 6.75 lb flywheel I suggest that one.
Old Oct 21, 2003 | 12:59 PM
whiteyg2rs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCon15s &raquo;</TD></TR><TR><TD CLASS="quote">whiteyg2rs knows whats up thanks a lot man</TD></TR></TABLE>
I think I should put that quote in my signature. I've picked up a lot of info over the past 3-4 years, thanks for the compliment.
Old Oct 21, 2003 | 02:07 PM
db8sirg's Avatar
itr 14.4
gsr 18
Old Jan 28, 2004 | 10:30 AM
SimbaDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">
Flywheel weight will affect the crank shaft rotation than the engagement of the clutch. IMO the lighter the better. If Comptech still makes their 6.75 lb flywheel I suggest that one.</TD></TR></TABLE>
do you plan to still be daily driving w/ a 6.75? in traffic...?????
Old Jan 28, 2004 | 11:04 AM
tilt's Avatar
my gsr fly is 18lbs
Old Jan 28, 2004 | 11:06 AM
locass316's Avatar
get the itr and lighten it a little.
Old Jan 28, 2004 | 11:22 AM
GPoodle
Guest
Posts: n/a
Default Re: (locass316)
Anyone know the approx. cost to have a flywheel lightened?
I picked up a 00' ITR flywheel for $80 shipped and I'd prefer it a little lighter. Thx.
girliehonda
Jul 9, 2007 07:29 PM
tekstyle
May 13, 2004 08:19 AM
betsuni
Sep 7, 2001 04:51 PM
BishopB18C1
Jul 31, 2001 03:51 AM
