HELP! my brake pedal goes down to the floor!
Old Oct 13, 2003 | 10:41 AM
Ya@inlinePRO's Avatar
Default HELP! my brake pedal goes down to the floor!
hey guys, last night i was drivin, and suddenly my pedal goes down to the floor. not instantly but it goes down slowly, and the car doesn't stop very well.
my first thought was air in the system, so we bleeded it today, and drove and it still did it. its on a 92 integra non abs. anyonne know the problem, i think its the brake master cylinder, but i'm not sure... i wanna be sure before i shell out 100 bux for the master cylinder...
thanks!
Old Oct 13, 2003 | 11:00 AM
Denny's Avatar
Default Re: HELP! my brake pedal goes down to the floor! (kwik2nec)
most likely brake master cylinder
Old Oct 13, 2003 | 11:21 AM
Default Re: HELP! my brake pedal goes down to the floor! (Denny)
thought, you guys know of anyway to see if there is a leak anywhere else?
Old Oct 13, 2003 | 01:20 PM
JimBlake's Avatar
If there's a leak anywhere else, you'll see a puddle of brake fluid somewhere. And the level in your reservoir will drop.
It can leak thru the piston shaft, into the vacuum booster. But that doesn't really cause the pedal to sink.
I really think it's a bad master cylinder.
Old Oct 13, 2003 | 01:56 PM
Rory Breaker's Avatar
Check for fluid around your brake pedal and the firewall for an MC leak, as thats what it sounds like.
Old Oct 13, 2003 | 05:01 PM
NuclearB18B's Avatar
Default Re: HELP! my brake pedal goes down to the floor! (newgsrdriver)
i have this happen to me every once in a while. that's exactly what i did not want to hear. lol...
Old Oct 13, 2003 | 05:27 PM
slowgoing92teg's Avatar
Its your master for sure. Same thing happened to me. Get it fixed with the quickness.
Old Oct 13, 2003 | 06:15 PM
Default Re: HELP! my brake pedal goes down to the floor! (JimBlake)
how long do you think it would take to drop, if it were a pinsize hole? is there anyway to make sure its the master before i replace it?
Old Oct 13, 2003 | 07:13 PM
emanLS's Avatar
u better go for osme further testing on the highway. a good way to check for poor breaks is to up to around 125-130 and the swing onto an off-ramp. You will definitely know if they work after that
Old Oct 13, 2003 | 07:24 PM
ek9dc2's Avatar
It is your master cylinder,Its leaking past the seal in sideyour master,they usually dont leak into the bb
Old Oct 13, 2003 | 09:34 PM
THE94GSR's Avatar
Default Re: (ek9dc2)
its ur break master cylinder get i had this problem a couple of months ago... i changed it and the problem was fixed
Old Oct 13, 2003 | 10:59 PM
jdmintegra1994's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kwik2nec &raquo;</TD></TR><TR><TD CLASS="quote">hey guys, last night i was drivin, and suddenly my pedal goes down to the floor. not instantly but it goes down slowly, and the car doesn't stop very well.
thanks!</TD></TR></TABLE>
$100? Where the heck are you getting it from? Non-abs MC's only set you back about $50. ABS is around $80...
another eg
Sep 1, 2015 04:31 PM
LOVEthatDC2
Sep 15, 2009 06:16 PM
bb4socal
Sep 4, 2006 09:51 PM
92integraVTECgsr
Oct 29, 2005 06:48 PM
MrEg
Sep 22, 2003 04:49 PM
