93 Civic Gountrol Problem?
Old Oct 13, 2003 | 07:09 AM
Jdm93civic's Avatar
Default 93 Civic Gountrol Problem?
Wasup i have a 93 Civic Coupe well i have had my civic lowered on for a while now.....but i have noticed that there is a werd problem with the ground controls........its mostly on the back....on the rear passenger side my ground control is almost lowered to the bottom.....and then i went to check the drivers side rear one and that one is almost half way down.......now my questions is why is one lower than the other but when you look at the car it looks even on both sides.......is this normal?
Old Oct 13, 2003 | 07:11 AM
SICKSOLSI's Avatar
Default Re: 93 Civic Gountrol Problem? (Jdm93civic)
could be a blown strut
Old Oct 13, 2003 | 08:01 AM
Jdm93civic's Avatar
I know is not a blown shock because i just got kyb agxs installed and i checked all of them like 2 days ago just to make sure.....but i checked on other forums and they said that this happens to a lot of civics......that one is side is higher that the other.?
Old Oct 13, 2003 | 11:20 AM
Jdm93civic's Avatar
i asked one of my best friends with a ceilca and he told me that he had the same problem..........one coilover was higher than the other but the car looked even....he had GC's with koni shocks on his 02 GT-S.......is there any problem with this shold i worry bout it?
Old Oct 13, 2003 | 01:39 PM
blackeg's Avatar
Default Re: (Jdm93civic)
it happend to my civic. same car, 93 coupe, and the passenger side sits a little higher than the drivers side. i noticed it with stock suspension, figured it would even out when i installed new springs/struts and it didnt. ive also heard of it happening to other people, so its kinda common. i dont believe its much to worry about. outta curiosity, how is the ride with the agx/gc coilovers? i have agxs now with arospeed springs and im seriously considering gc's.
Old Oct 13, 2003 | 02:20 PM
gribbs's Avatar
Default Re: (blackeg)
^^^^ Exact same thing happens with my 93 sedan after shock/spring install....quite common
Old Oct 13, 2003 | 04:23 PM
Jdm93civic's Avatar
the ride is really nice...........the GC and kybs is a good combo if you are on a budget.....it doenst compare to like Apex i Suspension or Tein or JIC but it is really nice.............
Old Oct 13, 2003 | 05:06 PM
hYbRiD EeEkAy's Avatar
the first thing i did to my hatch was GCs and KYB's. but i have the Gr2 non adjustables. fine ride, no bounce. good setup fr under 500.
when i look at the passenger side and the drivers side, the passenger side looksa bit higher, uti measured from the top of the fender archs to the floor and i got 22 inches all around so im guessing everything is equal in height?
Old Oct 13, 2003 | 05:10 PM
dantastic's Avatar
Default Re: (kwikEG)
GC's and AGX here.... none of the aforementioned problems....
Old Oct 13, 2003 | 05:32 PM
solo2slocivic's Avatar
the reason the spring adjustment is different from corner to corner is that the cars weight is NOT equal from front to back or side to side every corner has a different weight.... thats the main reason for buying coil over suspension so you can tune/balance the cars weight - corner weighting
gutted-dx
Suspension & Brakes
Aug 25, 2017 04:01 AM
JStroupe
21
Oct 30, 2011 10:37 PM
Bizoink
Apr 9, 2011 02:51 PM
zeke mccune
May 26, 2004 07:09 AM
Jdm93civic
15
Jun 9, 2003 09:07 PM
